L-Adapter
Thank you. But Alex's Post only indicates Toroidal for the L Adapter. There are 3 more for the Ultrabibs.
Any help is welcome
I use 2x15VA-7V (for controller and DAC) and one 1x25VA-7V (for Opamps) Talema incapsulated PCB type of toroids. L-adapter is feeds from 100VA 9V AnTek. 50VA should be sufficient, but I got 100VA in hands and use it. Controller PSU is set for 125mA CC, DAC is set for 210mA, and Opamps is set to 240mA for + and same for -. All is measured values. Hope it is clarifies your inquiry.
Hi Salas,
Will the L adaptor suffer from oscillation or performance degradation if the leads are long?
No oscillation, its not reactive, has no loop feedback from output to its voltage reference. Use thick leads if long though. Because thin leads resistance can drop enough voltage when the current they pass is significant. And that's obviously not a good thing, especially when the load fluctuates current pull.
You mean this guy? 😀
attachment.php
I hope to put an L-Adapter on it this weekend.. 😀
3x more powerful processing than the RPi 3 early testers say... Not to be leaking more clock noise in its PCB though I hope. Dim's feedback vs Rpi 3 will possibly tell us if there are subjective differences or other.
The truly interesting part is that the USB bridge chip is on a PCIe bus and the GbE controller is on an independent RGMII bus, so no more USB bottleneck.
However, all of this processing power and I/O speed might be coming at a price (noise).
We'll see soon enough.
