hi salas,
i measured again, it will be around 20cm, so longer than i predicted.
how thick should the cables be? or should i better change the setup to get shorter length?
and do you twist all cables from and to the psu? (sorry for the really beginner question
thanks, kind regards!
Nearer to 10cm length would be better if you can rearrange enough. Use AWG 14 or about so.
AC cables to PSU you twist, DC ones out of the PSU you don't need to twist. They don't create radiating fields. Just tie them together per output pair for maintaining a narrow loop area.
I seem to have populated a board with green LEDs. I know (think) this will give a higher voltage reference? By 0.4v or so.
Are they ok or should I swap in red ones. I thought I remember seeing someone populate neg rail green and pos rail red but maybe that was another thread!
36v across C1. 30v in.M1 was bad though, so you did well to replace. How much raw DC develops across C1?
Yes, J's are PF5102s. 30v is a bit higher than I need. I should be using 24v tranny but it's what I have for now.
Going to pull Q2 and all the other Js and Qs I haven't checked before trying it again.
No, could have been soldering or de-soldering. I use Hakko equipment for both. Maybe just my error.Any idea as of why? Too long under the iron maybe? Is the iron mains grounded?
Hello Salas!
I am new to diyaudio.com and have yet to master electronics or circuit design.
Nevertheless, I wanted to build an external PSU unit with two different voltage outputs of 24v and 12v at a maximum of 0.5A for each output.
Is this design suitable for my needs?
If yes, I would also like to inquire about ordering the boards.
Thank you beforehand!
Hello,
Yes, it's suitable. The board includes two positive sections and one negative, so one board will cover your plan
All essential info about this design and its practical application is concentrated in post #1
Boards and key components are ordered from time to time in a group buy organized by member Tea-Bag
You could PM him for availability
I just finished the BA-3 preamp with Salas SSLV1.3 UltraBiB shunt regulator.
This combo is mind-blowing, the best preamp I ever built/had.
Big thanks to Salas for this excellent project.
I would like to test this regulator with my other system.
I need to get +-12 volts but I have only 2x 22V trafo at this moment.
Can drop almost 18V at regulators - standby current 40mA and the peak 200mA (peak for max 5 seconds every few minutes)?
I have plenty of heatsink.
- Power Supplies
- Salas SSLV1.3 UltraBiB shunt regulator
