Quasimodo results (ONLY)
Toroid Int AB
1500VA 230VAC, unwinded some turns for lowering sec voltage to 2*50VAC.
Cx=10nF
Cs=100nF
Rs =22ohm
Picture shows undamped also.
Talema 62065-P2502
25VA, 2 x 22VAC
Cs = 1uF
Cx = 10nF
Rs = 33R
Note these Cx, Cs values are different from the default Quasimodo values, These values are the ones used in the onboard snubbers of the UDP3.
Reactions: Monk55
Breve Tufvassons TEZ16 16VA , 230V in 7.5V out
Cx = 10nF
Xs = 150nF
Rs = 220 - 270 Ohm
Myrra 45031 10VA , 230V in 2x6V out
Cx = 10nF
Xs = 150nF
Rs = 270 Ohm
Hahn BVUI3040173 10VA , 230V in 2x21V out
Cx = 10nF
Xs = 150nF
Rs = 1KOhm
Talema 70064k 25VA , 230V in 2x18V out
Cx = 10nF
Xs = 150nF
Rs = 27 Ohm
Talema 70065k 25VA , 230V in 2x22V out
Cx = 10nF
Xs = 150nF
Rs = 27 Ohm
Talema 70060K 25VA , 230v in 2X7V out
Cx = 10nF
Xs = 150nF
RS = 12-15 Ohm
Talema 70063K 25VA , 230V in 2x15V out
Cx = 10nF
Xs = 150nF
Rs = 27 Ohm
Talema 70053K 15VA , 230V in 2x15V out
Cx = 10nF
Xs = 150nF
Rs = 68 Ohm
