Oh, I forgot those.where is the red led near the right opamp?
Seems to be good now, after adjusting the potentiometer to 1K/9K.
The output is still "wavy" or is this how it supposed to look?
Thanky you btw!
Oh, I forgot those.
Thanky you btw!
Its supposed to be a straight line. perhaps this is oscillation?
I have no idea, but I couldn't fix it, so I remade the whole thing from the schematic in #343.
The output is still bad tho.
What I've noticed is that modifying the potmeter values does nothing to the output, but I cannot see any wiring mistakes.
+If I lower the value of the 10KuF filter cap, the sawtooth becomes steeper, but increasing doesn't fix the issue.
Tried 28V, 24V, 9V and 8V, but it doesn't change the output.what is the input voltage? your regulator may be dropping out.
It may be just a simulation error.
- Power Supplies
- low noise Pre-Amp / DAC power supply MJE15034 TL072 Regulator based on STUDER 900
