PC Based Computer music servers, crossovers, and equalization
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
Thread Tools
Old 19th March 2020, 11:20 PM   #241
xorcz is online now xorcz  Czech Republic
Originally Posted by HenrikEnquist View Post
I also don't need any gui for myself, but I certainly see the use case for one...
Great to hear! I was thinking about the active crossover, found articles of R. Taylor, but the jump was to big. And then came T5's paxor with the GUI, which was just a small step so I am rebuilding my 3 way speakers to active.
Old 20th March 2020, 07:37 PM   #242
cube75 is offline cube75  Netherlands
I have tried to make the internal buffering robust against scheduling issues. But I only have experience from running it on modern PC hardware, and there I would say realtime stuff isn't needed. It runs just fine while playing movies from Netflix in Firefox for example, which is quite heavy since uses with software video decoding. In the same conditions I had lots of dropouts with BruteFIR. On a Pi I have no idea, would be great if someone wants to test a bit
I ran some time an optimization script. (also on Github)
It installs does a couple of ''optimizations'' on the OS.
I did this because I had some dropouts with Brutefir. Didn't solve them. Chancing buffersizes did.
Just getting the basics right did more I thought.
Camilladsp with rate control runs solid. Standard out of the box Raspbian
Old 20th March 2020, 09:49 PM   #243
HenrikEnquist is offline HenrikEnquist  Sweden
Thanks for sharing!
Old 20th March 2020, 09:52 PM   #244
There is a new version in branch "socket". The main thing is that it can now be controlled via a websocket. It's possible to reload the config, switch config file, and even upload a new config directly as yaml.
Check the readme for a few examples on how to do that from Python!
Old 22nd March 2020, 07:27 AM   #245
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Very cool
I've tried to compile this branch, but something went wrong i guess:
pi@SuperBPI:~/socket_camilla/camilladsp/target/release $ /home/pi/socket_camilla/camilladsp/target/release/camilladsp
CamillaDSP 0.0.10
Henrik Enquist <henrik.enquist@gmail.com>
A flexible tool for processing audio
USAGE:
camilladsp [FLAGS] <configfile>
FLAGS:
-c, --check Check config file and exit
-h, --help Prints help information
-V, --version Prints version information
-v Increase message verbosity
ARGS:
<configfile> The configuration file to use
pi@SuperBPI:~/socket_camilla/camilladsp/target/release $ /home/pi/socket_camilla/camilladsp/target/release/camilladsp -p
error: Found argument '-p' which wasn't expected, or isn't valid in this context
USAGE:
For more information try --help
What i did was.
1. mkdir socket_camilla, cd socket_camilla
2. git clone GitHub - HEnquist/camilladsp: A flexible linux IIR and FIR engine for crossovers, room correction etc.
3. cd camilla
4. git checkout socket
5. git pull
I need to disable pulseaudio for the piCorePlayer i'am trying it on so i did this?!:
cargo build --release --no-default-features --features alsa-backend --features 32bit
So where did i go wrong.
Btw. camilladsp is working also on this build, but no -p
Btw(2): I have it running on the famous piCorePlayer now. I've created/modified excisting script on the dist. to an ugly init.d script which starts the camilladsp as a Daemon when piCore(The linux RAM OS) are booting...
It's working perfect, no glitch no noise 100% good, and very low CPU usage ~2-3% too.
Jesper.
DCG3 Dual DCSTB, AK4490 Dual SuperDAC
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html. Github https://github.com/Lykkedk/SuperPlayer
Old 22nd March 2020, 08:22 AM   #246
The websocket part gets disabled by the --no-default-features flag. Just enable it again by adding "--features socketserver" to the command:
Code:
cargo build --release --no-default-features --features alsa-backend --features 32bit --features socketserver
Old 22nd March 2020, 08:55 AM   #247
Boden is offline Boden  Netherlands
How do you gentlemen then check whether the dsp functions as intended? Loop-back testing?
Old 22nd March 2020, 09:19 AM   #248
lykkedk's Avatar
Code:
Perfect... thanks
pi@SuperBPI:~/socket_camilla/camilladsp $ /home/pi/socket_camilla/camilladsp/target/release/camilladsp -h
CamillaDSP 0.0.10
USAGE:
camilladsp [FLAGS] [OPTIONS] <configfile>
FLAGS:
OPTIONS:
-p, --port <port> Port for websocket server
ARGS:
Old 22nd March 2020, 01:01 PM   #249
I measure, adjust the dsp, and measure again. Also my experience is that if something is wrong, more often than not it will be very wrong making it obvious that there is a problem. Like swapped woofer/tweeter signal or stuff like that.
Old 22nd March 2020, 06:57 PM   #250
Do you then measure filtered speaker SPL (acoustic transfer function), or filter transfer function (electric transfer function)?
CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.Hide this!Advertise here!
Thread Tools
The room correction or speaker correction? What can we do with dsp power now availabl Raimonds Full Range 233 28th January 2017 08:51 AM
Introducing OpenDRC, Open Digital Room Correction engine minidsp miniDSP 20 20th January 2016 06:37 PM
What the difference between dsp room correction eq and software correction erez1012 PC Based 0 10th March 2014 08:07 PM
Writing a Cross-Platform, Free Software Modeling Tool and TS-Parameter DB justinzane Software Tools 6 31st December 2013 07:55 AM
FS: DAC, room-correction, active crossovers, amp, speakers! taloyd Swap Meet 4 14th April 2009 04:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
