Daphile - Audiophile Music Server & Player OS
Hm, it looks like a streamlined distribution, unsuitable for any diagnostics. All "noncritical" files/options are removed/disabled. That is one of the reasons I do not like this dumbed-down approach. Plug&play for any hw never works reliably (especially for USB audio which has received many crucial patches into the snd-usb-audio module recently). Having no troubleshooting facilities means dead end.
For checking your DAC IRQ rate options you can try e.g. live installer of ubuntu (or my favorite Mint Mate) and play anything with aplay. That distro certainly has all the debugging options enabled. E.g.
Code:
aplay -v -D hw:YOUR_HW_DEVICE --dump-hw-params -f YOUR_FORMAT  --period-size PERIOD_SIZE -c 2 -r 48000 /dev/zero
You can try various period size, check what the hw_params file in /proc lists, and what IRQ rate the given command produces.
Ok, so, I plug the Revolution Dac on my laptop (OpenSuse Leap 15.2).
When no music is played I have ~50 interrupts/sec and when music is played I have the ~7000 interrupts/sec.
Here is my hw_params
Code:
cat /proc/asound/Revolution/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 44100
buffer_size: 88200
Here the lsusb -v
Code:
Bus 001 Device 007: ID 152a:8809 Thesycon Systemsoftware & Consulting GmbH
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x152a Thesycon Systemsoftware & Consulting GmbH
  idProduct          0x8809
  bcdDevice            1.02
  iManufacturer           1
  iProduct                3
  iSerial                 0
  bNumConfigurations      2
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          309
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      bInterfaceProtocol     32
      iInterface              3
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               8
        wTotalLength           72
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID               41
        bmAttributes         0x03 Internal programmable Clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            9
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     11 (CLOCK_SELECTOR)
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
          Clock Selector Control (read/write)
        iClockSelector          8
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             2
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmChannelConfig   0x00000000
        bmControls    0x0000
        iChannelNames          11
        iTerminal               6
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                10
        bSourceID               2
        bmaControls( 0)      0x0000000f
          Mute Control (read/write)
          Volume Control (read/write)
        bmaControls( 1)      0x0000000f
        bmaControls( 2)      0x0000000f
        iFeature                0
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID            20
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              4
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats         0x00000001
          PCM
        bNrChannels             2
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            4
        bBitResolution         32
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x02d0  1x 720 bytes
        bInterval               1
        AudioControl Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         2 Decoded PCM samples
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats         0x80000000
        bNrChannels             2
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass       254 Application Specific Interface
      bInterfaceSubClass      1 Device Firmware Update
      bInterfaceProtocol      1
      iInterface             10
      Device Firmware Upgrade Interface Descriptor:
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Manifestation Tolerant
          Upload Supported
          Download Supported
        wDetachTimeout                    250 milliseconds
        wTransferSize                      64 bytes
        bcdDFUVersion                   1.10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      33
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               8
    bLength                 9
    bDescriptorType         2
    wTotalLength          309
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              3
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength           72
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bClockID               41
        bmControls           0x07
        bAssocTerminal          0
        iClockSource            9
        bLength                 8
        bDescriptorType        36
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
        iClockSelector          8
        bLength                17
        bDescriptorType        36
        bTerminalID             2
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmControls    0x0000
        iChannelNames          11
        iTerminal               6
        bLength                18
        bDescriptorType        36
        bUnitID                10
        bSourceID               2
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            20
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              4
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bNrChannels             2
        iChannelNames          11
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface             10
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Upload Supported
          Download Supported
        bcdDFUVersion                   1.10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
Kernel parameter :
Code:
uname -a
Linux Legion 5.3.18-lp152.41-default #1 SMP Thu Sep 3 23:02:59 UTC 2020 (a4d139b) x86_64 x86_64 x86_64 GNU/Linux
grep CONFIG_SND_VERBOSE_PROCFS= /boot/config-$(uname -r)
CONFIG_SND_VERBOSE_PROCFS=y
And, at least ;)
Code:
aplay -v -D hw:Revolution  --dump-hw-params -f S32_LE --period-size 8 -c 2 -r 48000 /dev/zero
Lecture données brutes '/dev/zero' : Signed 32 bit Little Endian, Fréquence 48000 Hz, Stéréo
HW Params of device "hw:Revolution":
ACCESS:  MMAP_INTERLEAVED RW_INTERLEAVED
FORMAT:  S32_LE SPECIAL DSD_U32_BE
SUBFORMAT:  STD
SAMPLE_BITS: 32
FRAME_BITS: 64
CHANNELS: 2
RATE: [44100 705600]
PERIOD_TIME: [125 1486078)
PERIOD_SIZE: [8 65536]
PERIOD_BYTES: [64 524288]
PERIODS: [2 1024]
BUFFER_TIME: (22 2972155)
BUFFER_SIZE: [16 131072]
BUFFER_BYTES: [128 1048576]
TICK_TIME: ALL
Hardware PCM card 1 'Revolution' device 0 subdevice 0
Its setup is:
  stream       : PLAYBACK
  access       : RW_INTERLEAVED
  format       : S32_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  exact rate   : 48000 (48000/1)
  msbits       : 32
  buffer_size  : 8192
  period_size  : 8
  period_time  : 166
  tstamp_mode  : NONE
  tstamp_type  : MONOTONIC
  period_step  : 1
  avail_min    : 8
  period_event : 0
  start_threshold  : 8192
  stop_threshold   : 8192
  silence_threshold: 0
  silence_size : 0
  boundary     : 4611686018427387904
  appl_ptr     : 0
  hw_ptr       : 0
I do not understand this:
Code:
format: S32_LE
subformat: STD
channels: 2
[B]period_size: 44100[/B]
buffer_size: 88200
and this:
Code:
aplay -v -D hw:Revolution  --dump-hw-params -f S32_LE [B]--period-size 8[/B] -c 2 -r 48000 /dev/zero
  [B]period_size  : 8[/B]
  period_time  : 166
The second version would clearly require IRQ every microframe (125us vs. period time 166us). How did you attain the hw_params dump with period size 44100? My 2cents is playback through pulseaudio which configures very long periods when running in timer-scheduled mode (tsched = 1).
Try aplay with similar large period size and then measure the IRQ rate.
Oh, ok, got it, my mistake.
For period-size=8
Code:
SUBFORMAT:  STD
SAMPLE_BITS: 32
FRAME_BITS: 64
CHANNELS: 2
PERIODS: [2 1024]
TICK_TIME: ALL
Its setup is:
  stream       : PLAYBACK
  format       : S32_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  msbits       : 32
  buffer_size  : 8192
  period_size  : 8
  period_time  : 166
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 8
  period_event : 0
  silence_size : 0
  appl_ptr     : 0
  hw_ptr       : 0
and
Code:
access: RW_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 48000 (48000/1)
period_size: 8
buffer_size: 8192
For period-size=65536
Code:
aplay -v -D hw:Revolution  --dump-hw-params -f S32_LE --period-size 65536 -c 2 -r 48000 /dev/zero
SUBFORMAT:  STD
SAMPLE_BITS: 32
FRAME_BITS: 64
CHANNELS: 2
PERIODS: [2 1024]
TICK_TIME: ALL
Its setup is:
  stream       : PLAYBACK
  format       : S32_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  msbits       : 32
  buffer_size  : 131072
  period_size  : 65536
  period_time  : 1365333
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 65536
  period_event : 0
  start_threshold  : 131072
  stop_threshold   : 131072
  silence_size : 0
  appl_ptr     : 0
  hw_ptr       : 0
and
Code:
format: S32_LE
subformat: STD
channels: 2
period_size: 65536
buffer_size: 131072
Make more sens ?
No, no, thank you !
So, with no music, irq rate :
Code:
“sec 1: 71”
“sec 2: 87”
“sec 3: 63”
“sec 4: 63”
“sec 5: 63”
with aplay -v -D hw:Revolution --dump-hw-params -f S32_LE --period-size 8 -c 2 -r 48000 /dev/zero
Code:
“sec 1: 8037”
“sec 2: 8007”
“sec 3: 8053”
“sec 4: 8023”
“sec 5: 8007”
and with period-size=65536, same :
Code:
“sec 1: 8008”
“sec 2: 8023”
“sec 3: 8049”
“sec 4: 8040”
“sec 5: 8022”
I've installed the latest Daphile version daphile-20.08-i486.iso and I'm having problem with the cover art display. Upon installation, the cover art files (folder.jpg) are all correctly displayed. From the second use of Daphile onwards, every single album shows the same cover art picture. Anyone knows what happens?
Another observation is that the stop/start between tracks is very noticeable. This is okay for non-concert albums but the interruption can be quite distracting. Anyone has this problem as well?
Joined 2004
Folks:
I suspect my server's motherboard is fried, but would appreciate your opinion. The motherboard is an ASRock N3050B-ITX, which has been in service for about 4.5 years and has worked fine during that period. RAM is 4 Gb. The Ethernet connection at the server is via a powerline extender. The server is plugged into a Furman AC-215 surge protector (but not the powerline extender). A month or so ago, I went away for a long weekend and shut the server down. Upon my return home the server refused to boot up -- it would hang at the first screen (see photo). I installed a new thumb drive (on which Daphile is loaded) but did nothing more, and a couple of days (and many attempts) later it booted successfully. I assume the original thumb drive was not the problem, since the server would hang before loading Daphile. A few days ago we had a power surge and around that time the server again went offline; the result is the same as before (again, refer to the photo). I don't know if the surge is relevant, but them's the facts.
So is it likely my motherboard (or RAM) is toast? Is there another plausible explanation?
If the motherboard needs replacing, any suggestions? The standoffs in my server case (which I'd like to continue using) are arranged for ITX motherboards. I could always drill new holes and install standoffs, but given a choice would choose not to.
Thanks in advance for the feedback.
Scott
4.5 years is a long time for that poor little Bios Battery...
Before all else spend a dollar and replace it with a new one..;)
If you can boot into the bios screen currently then make a note of the settings on each tab as a quick reference if you need to reapply them after battery replacement.
bob
Folks:
I suspect my server's motherboard is fried ............................ snip .....................
So is it likely my motherboard (or RAM) is toast? Is there another plausible explanation?...................... snip ................................... Thanks in advance for the feedback.
Scott
...as the man says @Drone7...
If you don't have any TEST Standalone media (CD-ROM or USB flash memory stick) you can create a USB 'test' environment standalone tool by building a LIVE USB bootable disk... I'm just giving you a suggestion here out of many: Linux Mint Installation Guide — Linux Mint Installation Guide documentation
You can run Mint from the stick and/or you can install it on your 'server' machine (this way you'll find out whether the HDD might need replacement)... Draw your own conclusion.
Hi All, does anyone experienced track seek issue, when playing from Tidal? When to click somewhere in the middle of track seek bar, it just stuck for second and stops. So it`s impossible to navigate through track, just listen from beginning till end. I have tried few x86-64 releases and betas on Lenovo T series laptop with same issue. I have squeezebox Tidal plugin.
No such issue when playing from HDD, so it`s like Tidal plugin bug?..
