Another problem with my F5 build.
Hi again. I had a problem last week with the power supply for my F5 build. I found the solution to that one. I now have 26.3 volts +&- I have that voltage getting to my amp boards. I do not get anything from there. The LEDs don’t light up. There is no voltage across r11 or r12. Changing the potentiometers does not help or change anything. Obviously I have an error that I have made on both channels. Does anyone have any ideas? I can send pics to individuals. I would be happy to converse by phone as well.
Thanks.
Build Pics
Here are some pics.
I used the PSU version 3 build guide. The F5 boards were build using the version 2 I think. I am at work, so I do not have things handy right now. I did have a bit of confusion about how to make the final connections between the PSU and the F5 boards. My guess is my problem is there.
This is a minor issue that some of my fellow forum members may not agree with.
I see you have red as positive, black as ground, and green as negative.
I would prefer that you stick to the standard as red is always positive, black is negative, and green is ground.
Also, if you look at the pic below. I prefer terminal blocks because if I make a mistake, and I make lots too, it makes troubleshooting easier.
Dan
attachment.php
Found blocks on Digikey. I will make the recommended changes, as well as change the orientation of my capacitor board so that the connections are more easily accessible, as soon as I get the blocks.
Don’t worry about wire color. Just be consistent on both channels.
Your Jfets appear to be installed backwards. (and I think they are actually ZTXs...)
I bought a set just now. That is where I got my first set. I have ztx devices in the 2 appropriate places on my boards.
I also have another question. The blue trim pots that came with my F5 parts kit do not seem to have a stop point when turned counter clockwise. Is that normal or should I replace them as well?
