I am experimenting with the Tex Instruments JFE2140, a dual SOIC NJfet available from DK and other sources. Idss is higher than the LinearSystems devices, so you may have to lower the value of R9 (499 Ohms) to allow sufficient current to flow to the JFETs. gfs is lower than the LSK170s or LSK389's, but noise is the same.
Aren't those thd and thd+n numbers rather high?Completed my Mini Pearl SOIC boards. Measurements are with the boards on the bench and power connections made with clip leads.
Soundcard interface loopback
Mini Pearl noise
Mini Pearl 2mV input
The output was 590 mV, so about 49 dB gain
One of the interesting things which Groner did with his low noise amplifier (LinearAudio Volume 3 IIRC) was to provide test pads on the PCB with which you could match smt JFETs for Idss. With the power on you just place the JFET on the pads and measure Idss.
If you purchase a strip of 10 JFETs you will probably get enough good matches for two boards.
Quoting myself, sorry, these are now spoken for and not available any longer, thanks.Having a surplus set of MiniPearl SOIC boards
- Mini Pearl
