Ultimate 4U 500mm Chassis - Who is interested?
View Poll Results: Base Plate Option
Standard Aluminium 3mm or 4mm 5 23.81%
Aluminium + Custom Perforated Steel Base Plate 470mm to 480mm 16 76.19%
Voters: 21. You may not vote on this poll
Thread Tools
Old 18th January 2021, 01:16 AM   #961
astromo is offline astromo  Australia
astromo's Avatar
Originally Posted by gary s View Post
Thanks for the update Gianluca, for those contemplating adding front handles at some stage, what size hole needs to be drilled, what size screw is required and do they come with the front panel handle kit?
Provided that my eyes are seeing straight, I'm measuring 4 mm based on the "Front Panel 1U 2U 3U 4U 5U" CAD file that I found on the ModuShop website. Deference to Gianluca for the final word on the technical detail.
I'd expect that you'll have a metric drill bit in your shed that will do the job. Straight forward with my drill press when I did it the last time but I'd expect that careful hand drilling with the job piece clamped in place would get the job done (along with sufficient application of drilling fluid).
Old 18th January 2021, 01:39 AM   #962
gary s is offline gary s  Australia
Gianluca has confirmed the handle holes are half drilled 5mm dia - so one only needs a 5mm drill bit to finish the hole to suit the screws supplied with the handles.
Old 18th January 2021, 08:07 AM   #963
astromo's Avatar
Gianluca's the man. Gary, thanks for the intel.
Old 18th January 2021, 08:57 AM   #964
Yes, Gianluca is always very helpful, top service.
Old 18th January 2021, 09:29 AM   #965
Gianluca is online now Gianluca  Italy
Gianluca's Avatar
Thanks everybody for the kind words
Originally Posted by kasey197 View Post
Thank you kindly.
At the moment the only shopping option I can see for Singapore is FedEx Economy.
Sorry I had missed this post! Shipping charges to Singapore with EMS have been loaded, next time you place an order you can choose this courier over FedEx
Originally Posted by mnichols30030 View Post
I am inteterested in ordering two chassis complete kit if or when that is possible. Thank you. Mike
Hello Mike,
Sure, orders are currently closed because we needed to know the exact number of chassis we have to produce. As soon as we have finished producing them and we know the exact number of chassis left you'll be able to place your order
And here are some pictures which are going to make somebody happy
Dropbox - 1610964343543.jpg - Simplify your life
Dropbox - 1610964343528.jpg - Simplify your life
Old 18th January 2021, 09:41 AM   #966
astromo's Avatar
No worries Gianluca. I'm getting a tech fail - Error (401) - on the images.
Old 18th January 2021, 09:51 AM   #967
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Hello Mike,
Hi Gianluca
Those back panels look different than the dxf files.
Maybe the wrong photos?
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 18th January 2021, 10:07 AM   #968
Gianluca's Avatar
Yes, I have realized that was the wrong metal sheet since the Deluxe rear panels look similar. Here are some correct pictures of the covers and the cardas rear panel
Dropbox - 1610967951275.jpg - Simplify your life
Dropbox - 1610967951266.jpg - Simplify your life
Old 18th January 2021, 10:13 AM   #969
astromo's Avatar
Sweet!
Old 18th January 2021, 10:14 AM   #970
Looking good
Ultimate 4U 500mm Chassis - Who is interested?Hide this!Advertise here!
Thread Tools
FS: Dissipante 5U 500mm Deluxe DIYspaceW Swap Meet 11 8th April 2016 04:57 PM
Anybody interested in this unique chassis for DIY? siliconray Vendor's Bazaar 0 31st March 2012 09:37 AM
ultimate chassis HighTech Multi-Way 5 2nd October 2006 08:20 PM
Blank rackmount chassis available. Anyone interested? testlab Swap Meet 6 14th January 2006 06:26 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
