Taming Hum on two pre-owned Aleph Mini's
Old 9th January 2019, 03:52 PM   #11
Dennis Hui is offline Dennis Hui  Canada
Hoopy Frood
You can build a fine power supply with a centre-tapped transformer like the Hammond.
Its power rating is a bit low for both channels but I wouldn't discount it.
For PS boards, please check that they support the size of caps you intend to use.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 9th January 2019, 10:35 PM   #12
mpmarino is offline mpmarino  United States
mpmarino's Avatar
Hard to tell the scale, but do you think one of the chassis can handle 4 channels of heat? If so, you could make one chassis for the amps and the other for the PSUs. Even quieter for your horns.
Edit - I might have a set of brianGT boards buried somewhere if you want to make it all the same. Mine are blue i think.
Crazy Yankee.
Old 13th January 2019, 12:12 AM   #13
rhthatcher is offline rhthatcher  United States
I have spent time this week studying and documenting the boards in my amps. After doing all that, I found a goldmine in this thread.
Aleph with BrianGT boards - diyAudio
The spreadsheet that thread with cross references between Aleph J schematic, BrianGT Schematic, and BrianGT PCB label would have saved me hours. It is gold. I learned a lot in the process, though. The good news is that the spreadsheet an the schematic posted by bobodioulasso regarding using BrianGT’s boards for an Aleph J lined up with what I found. Once I moved on the green boards, that went super quick.
PDF/Pix are of:
My documented “As-Built” schematics for both amps, plus pix of boards with component locations. This will be useful for any work at the bench now or in the future.
Pix of schematics from bobodioulasso’s post. One is the Aleph J on BrianGT Boards. The other is titled “Aleph 30 mod” and had red X’s on parts not included.
Questions that I need input on:
- What is R0? I have a 3 Ohm R0 resistor on the BrianGT board amp on the board, and 2.7 Ohm from board to speaker negative terminal on the other amp. It is not on bobodioulasso’s build, and crossed out with a red X on the other schematic. I’m thinking I remove them… Thoughts?
My amps dosn’t have the R27 on the boards. It’s open. I understand that is used for setting Bias. Should I put in a 68.2k resistor? Bias now is at 1.378A on one amp, and 1.355A on the other. Maybe a non-issue. Thoughts or experience on leaving R27 out?
- bobodioulasso’s drawing shows R27 (on his drawing R13 68k2) with a dashed line. Any clue on what the dashed line is?
Since I'm going to get in and tweak, are there any parts on the boards that could benefit from premium parts? I could imagine caps are candidates. Any favorite flavors?
Open items:
- Swap R14 and R16 on “Shorty” amp. It appears they’re backwards
- Jumper SG to –IN on "Shorty"
- Address R27 68k2 resistor when I know the right thing to do.
- Address R0 / mystery 2.7Ohm resistor when I know the right thing to do.
- Order Parts and update
- CRC PS
- Pots for R8 (DC Offset Adjust)
- C6 10uF on “Shorty”
- 2.5A 250V fuses
@mpmarino - What would you want for those boards?
Old 21st January 2019, 03:26 PM   #14
Weekend progress.
I gutted "Shorty" amp. I installed transformers, bridges, and a terminal block with AC mains in, cap, thermistors.
I'm stuck on the PS boards until my PCB spacers show up. My first amazon order is apparently coming from China, because delivery date is weeks out. Ooops. I have a batch set to come in on Wednesday. Perfect timing from return from a short biz trip.
I made some updates on the amp PCBs, too. Updated 'lytic caps, added missing caps, installed pots for Bias and DC offset, and swapped the resistors that were backwards.
Hopefully by this weekend I can fire it up for testing.
I bought a tap set for this. My wife is already sick of the "I'll tap that" jokes.
Old 26th January 2019, 01:43 PM   #15
I rebuilt the “Shorty” amp – pic is below.
It tested the output on some cheap speakers, then hooked it up my eXemplar horns. Good news: the hum in the speaker output is tamed. Sound is great.
The bad news – these Hammond transformers buzz louder than original speaker hum.
Is this a normal thing for Hammonds? Could it be the wiring job, or layout? If you see the picture you can see the AC mains going to a terminal block, then a thermistor and wire going to each transfomer. I had an orange drop cap at the terminal block, but pulled it.
Thoughts on how to fix it? Real estate is tight in this chassis, I opted for the hammonds because I measured up and all of the torroid options I looked at were extremely tight squeezes.
Power supply voltage = +/- 20.3V (was +/-17V before mods)
DC Offset 25mV Left, 30mV Right (was 34mV / 37mV before mods)
Bias Voltage = .592V / 1.26A (was .637V / 1.355A before mods)
I haven’t played with pots to tune the bia or offset, I want to solve the buzz first.
Old 26th January 2019, 01:53 PM   #16
mpmarino's Avatar
I'd try extending the wiring and pulling them out of the chassis. Maybe getting them away from right against that wall, or rotating one or both may help?
Crazy Yankee.
Old 26th January 2019, 07:01 PM   #17
MPMarino - thanks for the suggestion! I went to bed stumped about this, and woke up thinking about it. Your post got me inspired to try some things. After lunch I played around a bit.
- Transfomers out, no thermistors. Transformers still hum/buzz regardless of how I move them around.
- I found a corcom filter in my bag of tricks and thought "what the hell". I tried that between the switch/fuse and the transformers. Transformers still hum/buzz.
With the trannies out of the amp, it's quite easy to hear that it's the transfomers. And the speakers (in another room with long speaker cables) make great music. So it now comes down to figuring out the transfomers.
Before I bought the Hammonds I cut out circles the size of AnTek, Plitron, and Avel Lindberg torroids. The AnTek and Avels' won't fit on the bottom (traditional mounting) or standing up.
It looks like I could bolt a Plitron to the faceplate or maybe to an L bracket and have a couple millimeters to spare. Tight, but possible.
I could also try to put it on the bottom and move the PS boards perpendicular to their current configuration. I have a feeling the caps might not clear the binding posts or the amp boards. It would be a very tight squeeze.
Any other ideas on transformers? I'm assuming these won't work, so I'm looking for a "one and done" solution. 2x 15V or 16V or 18V @ 200VA-ish
Old 26th January 2019, 07:36 PM   #18
mpmarino's Avatar
Overload or DC on mains usually causes buzz. A toroid is much worse with DC on mains.
Maybe your secondaries are out of phase with each other. try reversing secondaries on one perhaps?
Recommend a light bulb (60-100) in series with mains so nothing get's too hot - in case.
Crazy Yankee.
Old 26th January 2019, 08:33 PM   #19
I played with swapping secondaries. Buzzz
Old 27th January 2019, 06:24 PM   #20
Today's experiment.
I decided to try and go back to original transformer (25VCT) with single rectifier bridge into the new CRC filter. So center tap to star ground, + from bridge to V+ input on the boards, - to V-.
Fire it up.
+/- 16.9V to rails. Good. 0.1V drop with CRC filter compared to original.
Plays nice music.
Transformer doesn't buzz. But I hear hum from the speakers when music is paused. Back to the original problem.
That leads me to conclude the dual rectifier bridge setup is key for noise reduction. I saw that when reading here Dual Bridge Rectifiers in PSU - why?
Side note. With the bias pot in, not "freewheeling" as original, the bias voltage was pretty close to previous dual rectifier / transformer and higher voltage rails. Good to know that it's doing its job.
Here are some options I'm thinking about now;
- Get a Plitron, see if I can stuff it in
If not, get a new chassis to hold 2 torrids and use that to feed both of my Aleph Mini-J's.
- I could consider transplanting all the guts into an all-new properly sized chassis, but that's the high price solution. I want to make what I have work before I go that route.
Thoughts or advice?
Taming Hum on two pre-owned Aleph Mini'sHide this!Advertise here!
FS: Pass PCB's (F5, Aleph AJ-X, mini Aleph or Aleph 30) poseidonsvoice Swap Meet 2 2nd January 2015 11:15 PM
integrated amplifier with aleph p1.7 and mini aleph vivanco Pass Labs 10 20th April 2011 04:48 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Aleph Mini / Aleph 3 PCB ready (?) croccodillo Pass Labs 5 27th July 2009 01:51 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
Copyright ©1999-2019 diyAudio
