Build This MoFo!
Build This MoFo!
Thread Tools
Old 17th April 2021, 06:32 PM   #2971
woody is offline woody
Build This MoFo!
For those of us not needing every last watt this design is capable of might not the voltage gain stage from the new Sony Vfet amp be a nice option. DIY Sony VFET pt 1
Old 17th April 2021, 06:50 PM   #2972
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Build This MoFo!
Originally Posted by RogerCl View Post
Two loudspeakers are currently in the planning stage:
- 4-way open baffle as a replica of the LX521 by Linkwitz.
- 2-way tweeter horn with bass in BR cabinet or CB activ equalised.
The music signal comes via audio PC and 8-channel audio interface. The speakers are actively separated via Acourate software.
Both speakers will be placed in the same room and driven by the same amplifiers.
The 18sound compression driver in the tweeter horn delivers 110dB and here I see the MoFo with its low noise as the solution. Best sound is added. The tweeters of the LX521 should also get their signal from the MoFo.
I want to supply the tweeter with the MoFo, which, if I understand this correctly, passes on the volume from the preamplifier 1:1.
I would like to solve all other frequency ranges via TPA3255 (class D) which amplifies the signal with a certain gain factor.
I will save different setups (crossover frequency, time delay and level) separately for both speakers in the Acourate setup.
Is it possible to synchronise this combination of MoFo and TPA3255 so that the volume change is synchronised for both types of amplifier?
Good choice for Class D amp. The standard issue TPA3255 has 22dB gain. The ones with PFFB have 16dB gain. The MoFo has 0dB gain. You will need some sort of preamp for MoFo with similar gain as the TPA3255. If using a DSP as XO to control all of this, changing a master volume will affect all in unison. However, a DSP will not be able to drive the MoFo to levels high enough to match your mids and woofers.
Assuming you want to be able to hit the typical 11w max power from a MoFo into 8ohms, you need sqrt(11v x 8ohms)=9.4vrms or 24Vpp. Any opamp based preamp with +/-15v rails and circa 22dB gain should be able to do this. Use that in between the DSP output and the MoFo.
The TPA3255 can also use a preamp as most sources have a hard time reaching clip with a 22dB gain. Also, the TPA3255 likes to see balanced input. So ideally you want a 6dB gain balanced output preamp to reach typical 28dB needed for most sources to hit max. In that case, the preamp for MoFo should be 28dB or so. Within the DSP you can make +/-6dB adjustments to dial in the relative balance of the woofer/mid/tweeter.
It goes without saying that to do this right you need a calibrated microphone and software like REW.
Old 28th April 2021, 07:56 AM   #2973
audiodesignguide3 is offline audiodesignguide3
After the good result obtain with EF180 instead of 6072A in Power Follower I am using now a new driver for the Inpol / Mofo using the 6Z51P.
The 6Z51P is near to the D3a and it is tested on the article of Bartola about russian pentode.
I will update you on result.
Old 30th April 2021, 05:35 PM   #2974
The sound is very good with the 6Z51P but remember to change the pins on socket because are different from D3a and EF180
I have use 290V, 4x39K 2W on anode and 100ohm on cathode with 470uF
I can share pcb files and the complete components list
Old 7th May 2021, 05:31 AM   #2975
Here the pcb, some little modifications are necessary to use the 6Z51P instead of D3a / E180F
Old 7th June 2021, 09:51 AM   #2976
In my case the 6Z51P have too much voltage gain so I have used the 6Z9P-E (same pcb without mods)
about 40W 1.5% thd and 148Khz at -3dB
File Type: jpg 6Z9P_8K25ohm_100ohm_06Vin_17Vout_8ohm_thd.jpg (96.5 KB, 588 views)
Old 7th June 2021, 03:00 PM   #2977
mindutis is offline mindutis  Sweden
mindutis's Avatar
Would be awesome if you could share the component values also.
My DIY amplifier
Old 7th June 2021, 05:20 PM   #2978
Current amplifier stage
R1,R2,R4,R5 1800ohm 1/4W 1%
R3 10Kohm 2W
R6,R7 220K 1/4W 1%
R9,R11 0.22ohm 5W Mills RMA5
C1 4700uF 16V Nichicon model UKA1C472MHD
U$1 0.68uF 400V Clarity Cap CMR or other audio grade MKP
R8 10Kohm multi turn
Q1,Q2 IRFP240PBF (it would be desirable to make a selection based on current)
D1,D2 zener 15V 1W
D3 zener 10V 1W
F1 fuse 10A FAST with fuse holder Mouser 534-4628
Cout min. 10000uF 50V Nichicon KG Mouser
Isolators Bergquist SP400-0.007-00-104 RS RS541-0856
Voltage amplifier
R1,R2,R18,R19 22Kohm 1/2W 1%
R3,R4,R20,R21 2200ohm 1/4W 1%
R5,R6,R8,R9,
R10,R26,R22,R23 39Kohm 2W
R7,R24 100ohm 1/4W 1%
R37,R39 47ohm 1/4W 1%
R11,R34 4700ohm 1/4W 1%
R12,R30 2 x 100Kohm 1/4W 1% to have 200K
R13,R28 4700ohm 1/4W 1%
R14,R29 150Kohm 3W
R17,R33 3.3ohm 2W
R25,R35 0ohm
R15,R16,R31,R32 220ohm 1/4W 1%
C1.C3 220uF 6.3V
C2,C4 33uF 400V
C5,C6 100uF 400V
CY1-CY8 10nF 440VAC
D1,D2,D3,D4,D6,D7,D8,D9 UF5406
D5,D10 zener 10V 1W
U$3,U$6 IRF840
U$11,U$7 33uF 400V Solen MKP
KK1,KK4 Extruded Style Heatsink for TO-220 Mouser: 532-513102B25
Isolator Bergquist SP400-0.007-00-54 RS 169-2177
Isolatos TO-220 nylon platstic Insulator hole size M3
or see on my web page
Old 18th June 2021, 07:13 AM   #2979
peppennino is offline peppennino  Italy
Galactic Hitchhiker
peppennino's Avatar
Build This MoFo!
Hi All,
As there's another similar project based on Mr. MR's MoFo:
LuFo Amp - 39w SE Class A from 28v Rail
I thought that I could ask a local transformer buider FIAT (link) to make a price for 30 pairs or more inductors with mounting frame having those features:
70mH, 5Adc and max 0,7 Ohm Rdc
It would cost 50€/pair (25€ each inductor) + shipping.
We can start a GB if interested
Main: SL-1210 + DL103 + Ext. PSU | 834P TRLH + α2δ PSU1 | UBP-X800 + Ext. PSU | RPi/Digi2 Pro | Mod. DDE3.0 | B1R2 | Aleph JZen (WIP) | Π4 - Cave: RPi | Modi2 | ACN | F3 (WIP) | SLOB (WIP)
Old 18th June 2021, 07:35 AM   #2980
Originally Posted by peppennino View Post
Hi All,
Is there a simulated data about Zout because cascode will increse this value.
Build This MoFo!Hide this!Advertise here!
Thread Tools
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 08:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 11:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 09:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 09:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
