Build This MoFo!
Build This MoFo!
Old 30th June 2020, 05:10 AM   #2701
autox is offline autox  United States
Thanks for pointing out these things about transformers. Now I know what my next round of reading will be on.
This is starting to look a lot like Susan Parker's Zeus SE pre: Zeus SE MOSFET Preamp Line Driver
BTH optical, Schiit Modi 2 Uber, Pass H2, Pass ACP+, DALAUDIO Studio 3886 R2, Paul Carmody Classix II
Old 1st July 2020, 05:06 PM   #2702
Upon further listening, the tone is off. It's missing a warm, full, lower mid-range. There's plenty of detail, and it sounds great for lighter, acoustic content. But anything rock - Dire Straits, Santana, Jethro Tull, Rolling Stones - it sounds somehow anemic, flat, no body or oomph.
I tinkered with the wiring on the Edcor without any luck. Using the full primary, which raises the DCR to 60, made a clear difference for the worse, which I believe is a function of the ACP+ being tuned for 30R. Taking the gain from 16x down to 8x didn't improve things.
A white noise test with my phone's RTA app didn't show anything wrong with the FR. Next chance I get, I'll try wiring the Edcor as an autoformer, as well as bringing the ratio down further.
Old Yesterday, 03:31 AM   #2703
Cinco is offline Cinco  United States
Cinco's Avatar
Hi autox, I suggest that you take a look at Papa's Official M2 Schematic
The tranformer as shown in his schematic is wired as auto-transformer for 15dB of gain (all you need is the transformer and R5 and C1 for freq comp). Your ACP+ would easily drive it with MoFo as load.
ACP+ gain of 9dB + autoformer gain of 15dB = 24dB gain total.
With 1V source that's over 15V. About 28Wrms into 8ohms.
It's not the DCR that determines the transformers impedence, it's the turns ratio, output Z of amp driving it and input Z of the load...
I learned lots from ZM about this stuff and in particular autoformer ins and outs.
A good place to start studies is Pumpkin Preamp thread.
Cinco
Old Yesterday, 04:28 PM   #2704
Cinco's Avatar
With the XSM10K:150 transformer, here's what I would try for auto-transformer wiring.
Since you chose a step-down transformer, notice the input goes in the output and the output goes in the input. Not ideal but may still work ok.
Luckily your ACP has less than 1 ohm output impedance.
By taking output from pin 2, you'd have a 2:8.2 + 2 (about 1:5) ratio, about 14 dB gain.
Compare from the HP out then the line out and see which one you prefer.
Cinco
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
