Build This MoFo!
Build This MoFo!
Old 9th April 2020, 09:49 PM   #2541
dBel84 is offline dBel84  United States
Congrats to Mike for the publication in AudioXpress - great to see this work being recognized beyond our community.
Old 10th April 2020, 12:56 AM   #2542
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Build This MoFo!
Mr. MR, he is.
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th April 2020, 11:49 AM   #2543
Michael Rothacher is offline Michael Rothacher  United States
AudioMaker.Tech
Michael Rothacher's Avatar
Build This MoFo!
YouTube
Visit AudioMaker.Tech
Old 11th April 2020, 04:55 PM   #2544
audiodesignguide3 is offline audiodesignguide3
Default Starting now with Hammond 195T5
I am starting now the experiments with Inpol / Mofo using a very good choke the Hammond 195T5 100mA 5A
Old 11th April 2020, 10:17 PM   #2545
jostwid is offline jostwid  Switzerland
Looking forward to your results
Old 11th April 2020, 10:56 PM   #2546
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Build This MoFo!
Same here.
I build, therefore I am.
Do not create problems where there are none.
Old 12th April 2020, 03:22 PM   #2547
Cpan is offline Cpan  Italy
Hi, what should be the input voltage in order to achieve the max power output from big MoFo and small MoFo?
Thanks, Claudio
Old 12th April 2020, 03:27 PM   #2548
Zen Mod's Avatar
Build This MoFo!
Vpp in value of rail voltage
Old 12th April 2020, 06:00 PM   #2549
ekosis is offline ekosis  Turkey
Default MOFO style with LATERAL MOSFETS
Hi all,
I built sth like MOFO with 2SJ162 four parallel. Inductor is handmade 75 MH wire diameter 1.40mm. Psu voltage 36v, I=4.0 amps. Both measurements and sound are stunning. Also the psu reversed as required.
My question is that: Iron core or air core is better ?
Mehmet.
Old 12th April 2020, 09:20 PM   #2550
TungstenAudio is offline TungstenAudio  United States
I have had some disappointing results with the power supply for my MoFo. I am using the MeanWell RSP-150, 27V. It was sufficient to establish a 2.4 or 2.5 Amp quiescent current at 26V, but has excessive ripple when the amp is being driven by a 1 kHz test signal. I am seeing high levels of distortion (>3%) on the output even with very low power levels. The amp clips badly at 1 Watt. I expected a 150W supply to be better behaved than this.
Adding a 70 uF motor run capacitor to the output of the SMPS made the distortion a little worse. I already have a 100 uF aluminum polymer cap at the power input on the MoFo board, but that is all right now. Looks like I need to build a CapMx if I want to use these SMPS.
Build This MoFo!Hide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
Power Acoustik MOFO 10, need box dimensions Spuddd Subwoofers 2 5th January 2017 10:46 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Power Acoustik MOFO-10 Sub subwo1 Car Audio 1 24th October 2003 08:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
