@ Mcdm
Always verify option you *can get money back* is available if not genuine transistors from unknow vendors
This one in Japan is OK https://www.ebay.com/sch/watanabeto...Y8MAAOSwnbZYDFkx&rt=nc&_trksid=p2047675.l2562
Datasheet of TM101-M Tokin.
Two SIT's in one package
well, I don't have these ........
Exotica like for the Cabinet of Curiosities..
Bipolar Darlington SIT's
I bought some Russian B-SITs. They do not curve trace as a triode.
What is the reference name of this Russian B-SIT's ?
Power transistors need higher current and voltage capability curve tracer for example:
Locky_Z , Frankentracer or something like Michael Rothacher Tectronix
AudioMaker | DIY Audio Projects & More | Page 2
Always excelent video VLOG #1: Curve Tracer, Big VFET, SIT Modelling, Ironamp
Edit: add curiousities about GanSIT's
It's probably been posted somewhere round these parts already, but as stated on page 9 of the attached PDF, the BSIT (at least the Russian ones) have pentode-like characteristics ("...выходные ВАХ БСИТ, как и у традиционных БМТ, имеют пентодный характер." ==> "...the output I-V characteristics of BSIT, like those of traditional bipolar [power] transistors, have a pentode character.").
Furthermore, they are enhancement-mode / normally-off devices, as conduction when VGS = 0V is considered a drawback in their intended application ("Из-за нормально открытого состояния транзистор со статической индукцией имеет ограничения по применению в ряде радиоэлектронных схем. Транзистор со статической индукцией с нормально-закрытым каналом, так называемый БСИТ, предназначенный для работы только в биполярном режиме, не имеет данного недостатка..." ==> "Due to the normally-on behaviour, the use of SIT in various electronic circuits is limited. SIT with a normally-off channel, the so-called BSIT, designed to operate in bipolar mode only, do not have this drawback...").
The bSITs I tried were also pentodey. I'll see if I still have some and post the #.
KP959A
Hah!
Tinker, Tailor, Soldier, Spy. Master of none.
Master of Self, perhaps?
Greetings,
M.
https://www.ebay.com/sch/watanabeto...9IMAAOSwRsJee2IC&rt=nc&_trksid=p2047675.l2562
Do KP959A show pentode curve because like Tokin this is two SIT's inside of one package connected in darlington configuration ?
What curves transfer is with two 2SK180 or 2SK182ES or THF-51S if darlington ? Or darlington of two Sony Vfet's ?
- Hockey Puck SIT 2SK180 by Tokin source NOS
