Hockey Puck SIT 2SK180 by Tokin source NOS
Datasheet of TM101-M Tokin.
Two SIT's in one package 😀
It's probably been posted somewhere round these parts already, but as stated on page 9 of the attached PDF, the BSIT (at least the Russian ones) have pentode-like characteristics ("...выходные ВАХ БСИТ, как и у традиционных БМТ, имеют пентодный характер." ==> "...the output I-V characteristics of BSIT, like those of traditional bipolar [power] transistors, have a pentode character.").
Furthermore, they are enhancement-mode / normally-off devices, as conduction when VGS = 0V is considered a drawback in their intended application ("Из-за нормально открытого состояния транзистор со статической индукцией имеет ограничения по применению в ряде радиоэлектронных схем. Транзистор со статической индукцией с нормально-закрытым каналом, так называемый БСИТ, предназначенный для работы только в биполярном режиме, не имеет данного недостатка..." ==> "Due to the normally-on behaviour, the use of SIT in various electronic circuits is limited. SIT with a normally-off channel, the so-called BSIT, designed to operate in bipolar mode only, do not have this drawback...").
The bSITs I tried were also pentodey. I'll see if I still have some and post the #.
KP959A
