50w Single-Ended BAF2015 Schade Enabled
If you want to build a 50W-SE-Schade-Monoblock and you want to bias it up to 3.1 A, then you are asking for heat
and a lot of aluminum to transfer that heat away.
My ones are working now for the last two years without any problems. Heatsink is made of a 8mm thick aluminum plate as heatspreader,
Modushop 5U - 300mm deep and 3U - 300mm deep heatsinks. And still around 67° C outside the heatsinks where the MosFet is mounted
inside. I can't go over 3.2 A bias - then the bias runs away...
Test it - and enjoy a 'warm' sound
Cheers
Dirk
:flame::flame:
Reactions: dantwomey
Cheers
Dirk
:flame::flame:
Heat is an understatement. My heatsinks are about 20 inches long (front to back), about 12 inches high, and the fins are about 2.25" tall. These heatsinks that were sitting on my shelf are huge compared to anything else I've built so I took a chance. I may have gotten away with it but after my heatsinks hit 60C I chickened out and put in a couple of small fans. I put a ton of work into this including making my own PCBs so I didn't want to see it go up in smoke.
I'm easily misled so after I build Randy's Aleph 30 I might repurpose this chassis and turn it into an Aleph 2.
After all, we're amp builders?
Dan
It depends on what voltage and current you are running. If your power supply is 60V and your current is 3.2A, the power dissipated is 60V x 3.2A = 192W, which is dissipated mostly by the two Mosfets and a tiny bit by the resistors. So the 192W is the total dissipation for the channel, not for the current source portion.
Thanks for the education. I'm smart, I'm just not as smart as ZM. 😉
frankly, I don't need debate ........ besides not being smart enough to draw conclusions from any paper :clown:
if I'm in doubt - I ask someone who's having experience with hsinks of interest
if there is no experience, time for proper in vivo test - fire up variac, big Donut, some hefty power resistors on hsink .......
yes, I believe in Pa's cunning, but he's too much cunning for me, mere Chicken
Does anybody know how this amp behaves with 4 and 16 ohm loads? If forced to choose between the two is one preferable to the other?
Edit: For context I'm wondering about driving a pair of dual-4ohm VC drivers that look like they hit about 30ohm in the box (winIsd). Hence being stuck with those to possibilities.
Hello Haze Head,
I can't really answer your question. But I have a 50W-SE-Schade-amp, that drives my 4 Ohm or 8 Ohm speakers with such an ease.
I have used this amp in an active speaker setup with the 6-24 AXO (active crossover) from Mr. Pass as well with some of my
passive speakers. But most of my speakers are pretty easy to drive. This amp has a lot of control.
I can't (and I think nobody can?) predict, how this amp will behave with your speaker setup.
If you have a strange impedance curve in your speaker behavior - normally with passive crossovers- but close to all speaker-
chassis have an impedance dip anywhere in the frequency range, than you could think about an impedance-correction - network
in your passive crossover (often done with speakers driven by tube-amps). Nothing new.
Cheers
Dirk
Reactions: Haze Head
