A guide to building the Pass F4 amplifier.
Old 4th July 2020, 04:39 PM   #1971
cal3713 is offline cal3713
I didn't see what speakers you are running, but one day you might try detaching one channel in each monoblock from the power supply and seeing how having a full dedicated power supply to a single f4 board sounds. With mine, I found that to be the best/cleanest and eventually quit paralleling the two boards. At first I just shorted the input of the unused board, but when I permanently disconnected it, I found out that even running idle was impacting the performance of the other board.
Old 4th July 2020, 05:23 PM   #1972
Norrlands Guld is offline Norrlands Guld  Sweden
Well noted. I might try that later on. I have German Physiks Unicorn MK2 speakers.
Old 4th July 2020, 09:21 PM   #1973
Your speakers look like a lot of fun. Would love to hear them. Definitely a significant step down in sensitivity from mine though, so ymmv in regards to using only a single board. My Coincident PREs are 94db @ 1w/m and don't drop below 8ohms. Congrats again on such a great build. Hope you love the f4s like myself and everyone else.
Old 4th July 2020, 09:36 PM   #1974
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
NG,
Great work!
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, F4, DCB1, VHEX +, USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece (sold) TDA1541A D3 with Abbas I/V, RH84
Old 5th July 2020, 12:49 PM   #1975
Default Norrland Guld Need Help!
Hi Team.
First amp went perfect. Biasing and offset all great
Second amp bias well on all transistor but the off-set is all over the place. Goes up and down at lower volt with the varaiac and when I start getting close to 230v the offset just goes way negative and out of adjustability.
Any suggestions? Can I have shifted the J-fets?
Old 5th July 2020, 01:05 PM   #1976
ggetzoff's Avatar
Hi Team.
Have you checked the orientation of everything? Can you get us some clear photos?
Start measuring the static values of your good amp as a reference, then check each one against the one that won't bias. You've got a wrong value or something not oriented right or a bad solder joint.
Fortunately, it's a simple, low parts count design.
Greg
Old 5th July 2020, 01:53 PM   #1977
Greg
I think the problem is solved. I disconnected the VU meter from the speaker terminal. Lets see how it goes now. Looks good so far.
Old 9th July 2020, 09:06 PM   #1978
amandarae is offline amandarae  Philippines
amandarae's Avatar
Are 10-11 mA Idss measurements for the 2SK170 and 2SJ74 good enough for the F4?
Thank you!
Abe
Old 9th July 2020, 09:06 PM   #1979
6L6 is offline 6L6  United States
6L6's Avatar
Yes, will be fine.
Old 9th July 2020, 09:11 PM   #1980
amandarae's Avatar
Thank you!
A guide to building the Pass F4 amplifier.Hide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1382 Yesterday 11:47 PM
A Concise Guide to the Published Amplifier Circuits of Nelson Pass rsdio Pass Labs 57 4th April 2020 06:28 PM
My,PASS ALEPH J and f4 xr000 Pass Labs 1 25th December 2009 03:20 AM
Idiot┤s guide to building Pass amps? judge Pass Labs 3 19th December 2004 11:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
