Aleph J for Universal Mounting Spec
Old 17th September 2020, 08:38 PM   #831
zygibajt is offline zygibajt  Poland
Halo guys,
I have built few Alephs in the past but have had some brake from DIY. I have bought a set of PCBs from DIY Audio store for AJ. Just to double confirm, the schematics from the beginning of the post use pots for bias, offset etc.. but I just want to build it as original and have it at hand as one of the amps I use depending on the speakers, can I simply use this schematics? I would use pairs of J74s 7-8mA matched. Obviously IRFP240 matched also. I mainly mean the resistors values, is it actual valid schematic of original?
Thanks in advance
Old 17th September 2020, 08:41 PM   #832
6L6 is offline 6L6  United States
6L6's Avatar
Yes. Of course.
EDIT: I would suggest one change, you really want a 2K pot at R7 to adjust DC offset.
Old 17th September 2020, 08:47 PM   #833
Many thanks! I just edited my question, that I mainly mean resistors values if they are correct as I'm just making the list to order Dale RN60D from Mauser.
And also out of couriosity, maybe this question has been asked already I saw in 6moons review the picture of original, some of the resistors are brown Dale, but part are some blue metal film, any reason for that?
I had been living with my own made Aleph 3 for quite few years in the past so hope building AJ will not be a problem for me.
Many thanks, and thanks for the tip with R7.
Old 18th September 2020, 02:55 PM   #834
RainfallSky is offline RainfallSky  Russian Federation
RainfallSky's Avatar
A new atemp was made.
Board size now 250mm x 63mm.
That took longer than I expect.
Need to rest for now and do something else.
Old 18th September 2020, 03:16 PM   #835
TungstenAudio is offline TungstenAudio  United States
Those are some good looking boards. It's good to have options for us semi-obsessive DIY builders.
Old 18th September 2020, 09:32 PM   #836
Thank you!
Small changes possible but I am mostly happy how it went right now.
Need to calm down and relook it with a fresh eyes later.
Old 19th September 2020, 12:35 AM   #837
Extreme_Boky is offline Extreme_Boky
Originally Posted by zygibajt View Post
Halo guys,
Thanks in advance
Yes. The bias will be around 1.25A per each "leg" and you will not be able to change it.
Also, match the R16-R19 in addition to matching the MOSFETs
The DC offset may not be a bang-on zero...
Old 22nd September 2020, 12:37 PM   #838
Yet another revision.
Small changes in traces, pads, a bit of footprints edit, some parts moved etc.
A place for wire jumper added in case only ubalanced (RCA) output will be used.
Lead space for jumper is 5mm
Inputs holes size is 1.2mm
I don't think someone would want to use thicker wire.
But some use coaxial cable and outer braid shield will go to.. hmmm.. GND?
Anyway all input pads have 1.2mm hole size.
"Aleph J" symbol as a copper pad now which I expect to be pretty with ENIG finish.
Also added text "Circuit by Nelson Pass. Layout by bla bla bla"..
Old 22nd September 2020, 11:58 PM   #839
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Generally, np uses blue Panasonic for the 3w resistors
Many thanks.
.... I saw in 6moons review the picture of original, some of the resistors are brown Dale, but part are some blue metal film, any reason for that?
"The geek shall inherit the earth"
2019 Burning Amp is Nov. 9 & 10 in S.F. Thread here on diyAudio:
Burning Amp 2019!!!
Old 24th September 2020, 05:39 AM   #840
toto34 is offline toto34
4K75 R5 caution must be 1 Watt
Aleph J for Universal Mounting SpecHide this!Advertise here!
Universal Mounting Specification rsdio Construction Tips 3 31st October 2011 11:51 AM
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 10:52 PM
Has anybody built an Aleph-x to this spec??? D3 Pass Labs 58 16th June 2004 06:08 PM
Spec on transformer for Aleph 5? Tony D. Pass Labs 8 24th April 2002 12:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
