Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Copper RCA connector
Old 16th February 2018, 09:33 PM   #1
Roo2 is offline Roo2  Australia
Default Copper RCA connector
I'm looking for a pair of female RCA panel jacks for the inputs to my AlephJ pass amp. Pure copper (OFC) appears to be a good option but most options appear expensive. I found the attached. I guess its possible the seller may be creatively using the word "copper" and they could be brass.. Anyway, two questions:
1. The attached photo doesn't show a ground lug. How would you connect the ground to this particular jack?
2. Can anyone suggest an alternative RCA jack that really is copper (not brass) and isn't expensive?
I understand the copper base metal needs to be plated for corrosion resistance, usually gold.
Old 17th February 2018, 08:33 AM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
For high current the conductivity of copper may be important, at low signal levels quality of contact is the priority
Old 17th February 2018, 08:48 AM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Copper is not strong enough for a connector.
Cheap fleabay connectors are steel plated with gold or copper.
Better quality are brass and professionals use Neutrik; Phono (RCA) Chassis Connectors - Neutrik
Nickel plated with gold.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th February 2018, 08:58 AM   #4
I use Rean from Neutrik, which are nice
Old 17th February 2018, 09:05 AM   #5
DF96 is offline DF96  England
Yes, copper is too soft and so will make a poor connector. I am going to guess that OFC copper will be particularly soft and so particularly useless for this application. It is unlikely that you will be able to buy such an item, as nobody should be daft enough to make one.
I can see two ground lugs on those connectors.
Old 17th February 2018, 08:35 PM   #6
Thank you all. The Neutrik ones with the socket look like a good option.
Old 17th February 2018, 09:26 PM   #7
rayma is online now rayma  United States
Tellurium copper is used for high quality connectors, and is nearly as machinable as brass.
Binding Post, Low Thermal Emf. Tellurium-Copper, Gold-Plated | Pomona Electronics
Old 2nd September 2019, 01:37 PM   #8
zalive is offline zalive
I bought recently couple of RCA sockets (from the OP) on fleabay, and I can confirm those are made of gold plated brass. Besides they're really massive.
Majority of manufacturers use (thicker) nickel plating underneath gold plating. Apparently it gives the gold that shiny look but it's not the best for audio.
Even WBT Nextgen 0210 Cu RCA sockets use bronze plating underneath thin (0.4 micron) gold plating. Only 0210 Ag RCA's are compromiseless in this respect - the only thing which is not silver in its signal part is bronze spring for the signal pin, which is obviously necessary for longevity reasons. There's a brass nut version, but it's disconnected from the signal path.
ETI Research FR-TC07 RCA sockets declare they don't use nickel or bronze or brass in the signal path. However they don't specify gold is directly plated on tellurium copper body - so it's possible they use some other in-between plating metal option which they hide. There's a brass nut, but it's disconnected from the signal path as well.
These two are probably best quality RCA socket options available; however I'd like if there was a cheaper option built on similar principles (tellurium copper or silver, low mass of signal conductor). However I see no similar female RCA from the Star Line, while Elecaudio produces tellurium copper RCA's, but unfortunately they use nickle plating as well.
Any suggestions? Any knowledge of other quality without compromise female RCA's, except less priced than WBT or ETI?
Old 2nd September 2019, 02:11 PM   #9
davidsrsb is offline davidsrsb  Malaysia
Pure copper jams the machining tools because it is too soft, so i would require a non standard and expensive production method
Old 2nd September 2019, 03:36 PM   #10
As I understand it, adding tellurium to copper will
1. make it more radioactive - but not dangerously so
2. make it more toxic - but not dangerously so
3. make it harder and so easier to machine and more durable
4. reduce conductivity - but not enough to do harm to an audio signal
Note that better audio performance is not a factor.
Copper RCA connectorHide this!Advertise here!
Copper plating with acid copper sulfate. Osvaldo de Banfield Construction Tips 17 19th September 2016 01:54 PM
WTB: Harmonic Tech Cyber-Link Copper or Digital Copper cable reaction Swap Meet 1 2nd July 2010 10:50 AM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
Finished my DIY Copper foil speaker cable, what connector to use? Guijs Everything Else 4 19th October 2005 10:31 PM
Copyright ©1999-2019 diyAudio
