Help Converting Line array into multi-way system?
Certainly, usig a tweeter with more limited verticals, the dispersion will better match the array’s.
iirc, ak used a ribbon with his Needles with 16(?) W3-871. They sounded decent. Losing he 871’s top end colouratiins really cleaned things up, and, at least on the short listen i had, did not suffer the discontinuity issues that one would expect.
dave
Oh....
Sorry- I'm a bit confused. While I do get the part about crossing over above where problematic room reflections occur. But if the tweeter is supposed to "beam" in the vertical direction, and will be rolling off below 3kHz at 18dB/octave, why are we
so concerned with the ceiling, which is more than four feet away? Is it because it's the nearest highly reflective room surface?
Thanks.
Hmm, with little time available and not recalling any of JG's LA doc ATM, my 'knee jerk' response is to point out that an 'infinite' line need not be room height, just ~71% of it and that one can easily get a 'close enough' F-6 dB beaming frequency with this simple math:
F-6 dB = 10^6/[wall angle*mouth width]
Example: 10" wide flat baffle x 60" height suspended in 4 pi space = 10^6/[180 deg*10"] = 555.56 Hz horizontal
10^6/[180 deg*60"] = 92.59 Hz vertical
2pi space mirror's the speaker's area/shape assuming it's perpendicular, so these frequencies will in theory be a 1/2 octave lower [0.7071x].
Floor, ceiling bounce: SBIR calculator
12 drivers/array.
2+tweeter as an MTM...8 or 10 as woofers... potential to get things together in a way that allows a 2.5way.
dave
Hi Dave. Hope you had a nice Holiday.
Now comparing different tweeters for use in Mtm.
For 8, 9, or 10 woofers, would you recommend even series/parallel or tapered attenuation towards the Mids? I understand that first option adds a few more dB.
Also, how would you recommend we make it 2.5 way (i.e. use a baffle step L//R filter, multiple low-pass driver frequencies, or cross all woofers to Mids at the baffle-step frequency)?
Quote"Our thanksgiving was a month ago :"
Oh! Canada...thanks for responding.
Quote:"
With that many drivers there are many ways to wire, i would not shade, and if going 2.5 way work it so one gets less thahow much lift."
Is it just me, or did we lose part of your sentence?
I'm anxious to learn ways to wire the lower drivers. Plus,
for example if 8 drivers are in regular series parallel, we get 4 ohms,while 9 drivers wired as 3 series sets of 3 in parallel gives 8 ohms. Which configuration would be preferred to provide the right level for baffle-step correction using the crossover alone?
999910d1637729048-help-converting-line-array-multi-system-12x3-png
If you put the drivers that are in the sections to the left in the diagram on the back of the box (or sides or top) or connect with a series L to roll off the top.
Either way it gives you a full 6dB of lift. I’d have to give some thot to losing less. Might need to lose a pair of drivers/side.
Tang Band W3-665sc is rated at 6ohms DCR,
8 Ohms nominal impedance. My drivers average 6.1-6.15 DCR on my B&H precision meter (8.2ohms?)
The rated sensitivity is 88dB/W/M, but their graph shows it between 84-86dB in the area below my 650-750hz(depending on final baffle width) low-pass filter. Note the slight LF rise as we approach our 150hz box cutoff (my sub cubes go up to 160Hz, 2nd order).
Ok,
I'm confused, and couldn't find this in Google.
How does the use of 3 drivers introduce shading(versus 2+2//2+2 series parallel)?
Getting "driver output between 1 and 6 BSC"-
That's quite a range.. How do you determine that?
To reiterate, I'm using free standing 5ft. monopole line towers about four feet from the rear wall, and about six feet from the sdewalls.
Thanks for the links. I'm reading the articles, but am already familiar with the work by Elliott. The one on the variable baffle-step circuit was interesting.
l'm still hoping someone who reads here has done something similar, and could share, so I can avoid unnecessary "cut and try" experimentation. Looks like I'll keep searching and try another forum...
Thanks for your time.
-Charles
Dave!
Sorry to be a pain butt-
Quote:"...I would not shade, not intentialy, but the use of 3 drivers, does introduce shading by definition but this is position dependent thing and here you would use it to try to get impedances and driver output somewhere between 1 and 6 dB BSC."
I have read a bunch, but still can't figure out what you mean(I'd originally mentioned 3x3 drivers):
If I use 9 of the W3 8ohm drivers, 3 paralleled sets of 3-in-series, I still get 8 Ohms, right? But-
HOW does that "introduce shading by definition"?
(Jim Griffin shows unequal groups give shading).
My driver line is within 3 feet of the floor, 4 feet from rear wall, 5.5 feet from ceiling, 6 feet from side walls, and.9 feet from the listening seat (all approx.).
Thanks.
-Charles
9 driver sis the suare of 3 so series/parallel brings you back to the nominal impedance of one driver.
If you have just 3, andm assuming nominal 8Ω, they are not all in parallel (2Ω) or series (24Ω) if you wire the drivers in series. Any other arrangment has 2 in series paralleled with a single driver. Series is best suited from 4Ω drivers, parallel with 16Ω drivers.
This gives a nominal 6Ω, but the 2 drivers in series, taken together, have about the same outut as the single driver. Put all 3 on front, and wire the outer ones in series and the outer drivers are shaded 3 dB down form the main driver.
dave
From a prosound POV: the fact that there's '3 paralleled sets of 3-in-series', i.e. unless everything is identical, each segment will in theory have a slightly different 'tone' or worse, unbalanced power sharing where one section can potentially 'hog' most of the available current with all the downsides this implies.
