Accelerometers to measure panel vibrations?
Thread Tools
Old 6th February 2021, 01:24 PM   #581
esl 63 is offline esl 63  Sweden
Originally Posted by Pano View Post
Strange, why would it be so microphonic? 5M input impedance can do odd things, but what in the Behringer could be turning vibration into sound?
All ceramic caps are highly microphonic, do not know if there are any in the Behringer, but many CD and DVD players that i have modified uses cheramic caps, also in the digital domain such as the clock circuit. Vibrations is causing huge amount of jitter.
Thats why there is sonic benefits from vibration damping on some electronics.
I recorded a -96dB (silence) and a 440Hz tone at -87dB on a CD and play it while knocking on the PCB.
Quite noticable.
Old 6th February 2021, 01:44 PM   #582
Remlab is offline Remlab  United States
Loctite Fun-Tak(Blu-tak) wins under 180hz and is a close second above that, so overall, it's easily the best value.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 6th February 2021, 03:32 PM   #583
I purchased one of these to compare to my non mass loaded type. They're both identical, save for the mass loading on this one.
Piezo Vibration Sensor - Large with Mass - SEN-09197 - SparkFun Electronics
I also purchased a few 10 mega ohm resistors to experiment with in the next sensor/cable I build. I have little understanding of electrical engineering, so if I'm doing something that doesn't make sense to those of you that do, please chime in. The sensor requires at least 10m ohms input impedance to work it's best, and the Behringer only gives about 5m ohms.
Old 6th February 2021, 05:27 PM   #584
So mass loading the sensor with the .72g weight(Supplied) , takes its resonant frequency from 180hz down to 40hz, which is definitely a good thing for taking panel measurements.
Old 6th February 2021, 09:14 PM   #585
I believe I need to switch this resistor out with the 10m ohm resistor, and then I’m set. Very easy to get to. Is it my imagination, or does this one look a little overheated?
File Type: jpg 7CBA944B-EBCC-492E-AA6B-042CAAF397BE.jpg (759.8 KB, 40 views)
Old 7th February 2021, 03:42 PM   #586
Pano is online now Pano  United States
Pano's Avatar
I'm not sure what the mass loading will do for you, but it will be interesting to see what you get. One would think that the mass has to wiggle while somehow a part of the piezo strip is supported.
Take the Speaker Voltage Test!
Old 7th February 2021, 04:08 PM   #587
Yes, I agree. It's construction is a little counterintuitive compared to the flat strip, but It's pretty inexpensive though, so I may as well give it a shot.
  Reply to this post
Accelerometers to measure panel vibrations?Hide this!Advertise here!
Thread Tools
Want to get Accelerometers/Vibration Sensors sdep777 Equipment & Tools 2 20th July 2018 06:39 AM
Moving Magnet Sub with accelerometers and DSP eriksquires Multi-Way 0 27th May 2018 02:57 PM
Do you measure then listen or listen then measure? midrange Multi-Way 34 5th October 2017 10:45 PM
Accelerometer to measure the loudspekaer's box vibrations diypass Multi-Way 15 24th February 2017 01:15 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
