Filter recommendation (using Hypex Software Design)
Thread Tools
Old 16th December 2019, 01:15 PM   #1
Geertidow is offline Geertidow
Default Filter recommendation (using Hypex Software Design)
Dear forum members,
As I am pretty far outside my comfort zone, I hope to offend no one by asking. A forum search did not give me the answer I was looking for (if there is any).
My father-in-law and I have converted my B&W CM8 S2 speakers to active monitors by removing the filters, replacing cables and using two (one per speaker) Hypex FA123 modules.
B&W CM8 are three-way speakers, 4 Ohm (in contrast to what they market), have crossover frequencies at 350 and 4000 Hz and have two identical, parallel mounted bass drivers.
I've spend a whole day measuring using REW and and UMIK-1 microphone and building filters to get the hang of the REW software. The first results are promising. As I will embark on another day of measuring together with my father in law (who has deep knowledge on the physics of sound and the working of audio electronics but no experience in the software itself) I hope you can provide me with some tips.
My questions would be:
1. What would be the most logical order of building the filters/adjusting the timing? I have used this approach so far: Using REW to Determine Time Delays Between Drivers - Technical/Modifications - The Klipsch Audio Community.
2. What would be, given the type of speaker (B&W CM8 S2) be the most logial filter design. I have started with a fourth order Linkwitz-Riley filter but I had to delay th tweeter 40 microseconds for a proper frequency response curve.
3. What is the optimal microphone distance for designing the filters?
4. Does anyone have any general recommendations for this project?
Thanks in advance,
Geert
Old 16th December 2019, 05:05 PM   #2
Deni09 is offline Deni09  Hungary
Formerly YSDR
As a general advice for DSP crossovers is that, you can relatively easily adjust the individual driver responses to be flat over a wide bandwidth before applying the crossover filters. This way it's easy to experiment with different crossover points and slopes, because the natural response of the drivers are less dictating the result. This way, timing adjust is the last thing in the row.
But attention to tweeter response flattening, don't do it loud.
Old 16th December 2019, 08:36 PM   #3
AllenB is offline AllenB  Australia
AllenB's Avatar
Measuring and simulating are a natural step regardless of whether you are doing an active or passive network, so I'd have the crossover designed first. This is important so that you can take the necessary steps in designing a crossover. Then translate it into Hypex as a separate step.
Old 16th December 2019, 10:51 PM   #4
AllenB's Avatar
Thinking about this more, why not copy the passive as a first step (or didn't you like it before)? Then you can modify and equalise. Let us know if you want to go this way.
Old 17th December 2019, 11:19 AM   #5
Thanks for your reply.
So far, I've tried an measured a number of possible setups.
In general, it seems that 2nd order LR filters both measure (REW, nice freq response cruve) and sound better ('coherent') than 4th order LR filters.
However, I've come to the discovery that the best sounding setup seems to be:
Bass: LR2nd order lowpass at 240 Hz.
Mid: LR2 240 Hz (highpass) + LR2 2000 Hz (lowpass).
Tweet: LR2 2000 Hz (highpass).
Due to safety of the tweeter I've raised the 2000 Hz crossover to 2400 Hz.
Would it be best to raise the tweeter crossover to +/- 3000-4000 Hz so that the segment of 1000 - 2000 Hz is done by the mid speaker?
Based on the measurements (as YSDR suggested) the mid speaker would be perfectly capable of doing this, but I'm a little lost since the 2000 Hz crossover tweeter sounded so nice. But I don't want to ruin my tweeter at the first party.
Old 17th December 2019, 12:13 PM   #6
AllenB's Avatar
The default crossover seems to be at 4000Hz. This may be a little on the high side for the 5 1/4" mid, guessing it may explain your preference. Have you considered making two crossovers, one just for you and one on party mode.
Old 17th December 2019, 12:17 PM   #7
That is an excellent consideration, but risky.
I'll try and test the crossover at 3000, 3500 and 4000 again.
Old 18th December 2019, 12:54 AM   #8
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
One question, the crossovers you have tested, were they 2nd order acoustic crossovers, or just the default 2nd order filter available in the package you are using?
a 4th order electrical filter will generally not give you a fourth order acoustic result unless you have very wide bandwidth speakers being crossed over well inside of their bandwidth. However a second order electrical filter will often give you a 4th order acoustic roll off.
Regardless of what technology you are using to create your filters, passive, analog active, or digital active, you really want to be aiming for the acoustic targets that create the best result (and this needs to take into account what happens off axis as well), not worrying about which electrical implementation to use. Almost always you will end up with asymmetry in your filters to achieve symmetry in your driver summing, and a coherent result.
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 18th December 2019, 06:21 AM   #9
Thanks Tony for your reply. I think I create active digital filters using Hypex software.
Here wouls be my summary of remaining questions so far:
1. Can anyone guess if a 2nd order filter at 2000 Hz is indeed to low for a tweeter from B&W in general? I can't find any data on the CM8 S2 models.
2. Should I reverse polarity on my mids speakers when using 2nd order filters on my 3 way speakers when building digital filters?
Old 18th December 2019, 07:06 AM   #10
AllenB's Avatar
The hypex software wasn't necessarily made for crossover design. You use it to set up your filters. You ask here some very important questions, which we may or may not take a guess at, yet this is the very reason we use crossover simulation software and a systematic approach.
I don't mind helping you cut a few corners but the quality of the information may be limited. For example, I would guess that a higher order filter will do the most to protect your tweeter. Try something similar to the original crossover slope at 4k, and compare that filter response to a higher order at 2k. Notice whether the sub 1kHz region is no higher than before, preferrably lower.
With regards to your second question, measure it afterward, each driver separately and then together. Overlay them if possible and post here.
Filter recommendation (using Hypex Software Design)Hide this!Advertise here!
Thread Tools
Hypex AS2.100 not discovered by Hypex Filter Design software rskriver Software Tools 0 24th July 2019 03:31 PM
Hypex DSP Design software and data files eriksquires Class D 0 1st January 2016 09:04 PM
Active filter design software lochness Tubes / Valves 25 11th July 2008 12:04 AM
design software for active filter dick van nierop Chip Amps 7 20th March 2006 04:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
