Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Old 17th July 2019, 06:31 AM   #1361
phase_accurate is offline phase_accurate
The HF204 is basically a HF144 with an adaptor. If you don't need a 2" you can as well use a HF144.
The B&C prototype elliptical horn shown in the B&C coax thread would probably be nice for the HF1440 as well. But I guess if there is no need to cross below, say 700 Hz, an LTH142 would probably also be nice.
Charles
Old 17th July 2019, 09:16 AM   #1362
4real is offline 4real  Netherlands
Originally Posted by docali View Post
The LTH142 is the smoothest but the Selenium is the best of all. It has the least beaming and by far the best low frequency extension and a first listening was very promising. This opens up the possibility for a much lower cross-over point.
How fair is it to compare these horns with vastly differing coverage? Obviously the Selenium has the least relative beaming, it's only a 40x20 horn compared to the 60x40 of the XT1464. Depending on the environment, it could still turn out that the wider horn suit one better.
Do diamonds shine on the dark side of the moon?
Old 17th July 2019, 10:49 AM   #1363
Ro808 is offline Ro808  Netherlands
China...
File Type: jpg DCX50 in 2-Way + Nexo 15 Woofer_pub.jpg (85.6 KB, 337 views)
Old 17th July 2019, 11:10 AM   #1364
It's not fair
Crude 400Hz conical of decent size:
Old 17th July 2019, 12:13 PM   #1365
peterbrorsson is offline peterbrorsson  Sweden
Charles
I have a Selenium 4750 90x40 2 inch horn so it suits me. However the build quality of the horn is atrocious. Looks like a child joined the horn with the throat. Package was marked "Proudly made by Harmon/JBL"
For the moment I'm an outcast, I have put Visaton FRS 5X in them)
Old 17th July 2019, 01:17 PM   #1366
The HM4750-SLF is bi-radial horn with slot.
The HL4750SLF is basically a slightly modified/upgraded JBL 2386.
If you can live with a slightly higher cut-off and get a wider dispersion as a bonus, this truncated clone is a better deal:
Old 17th July 2019, 01:43 PM   #1367
Originally Posted by Ro808 View Post
The 4750 is basically a slightly modified/upgraded JBL 2384, except for build quality/durability.
It's also very expensive.
If you can live with a higher cut-off and get wider dispersion as a bonus, this truncated clone is a much better deal:
This is the one I have:
JBL Selenium HM4750-SLF 2" Throat Bolt On Large Fiberglass Bi Radial Horn 90x40 | eBay
Old 17th July 2019, 01:58 PM   #1368
Both:
Old 17th July 2019, 02:41 PM   #1369
2386, check the throat.
Tip: compare it to the K402 throat.
It's the onset of...
Old 17th July 2019, 04:44 PM   #1370
I'm still intrigued by the Reflector design. Would be cool to make a low budget version of it. Of course you could buy all the same components for much less than the asking price, but I'm thinking of something even more budget friendly: XT1464 with HF146 as a basis. Now finding half decent budget 15" or 18" woofers is tricky. The best bang for buck I could find was Oberton 18B450. They are €165,- a pop. You'd then need just under € 1000,- for only the drivers of one side.
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 09:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 06:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 7th December 2011 11:51 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 12:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 07:32 PM
Copyright ©1999-2019 diyAudio
