Open source Waveguides for CNC & 3D printing!
Old 24th April 2018, 04:31 PM   #71
augerpro is offline augerpro  United States
Thanks Christoph. I'll tighten up the fitment in the next designs. So if I understand correctly, the major improvements to the simmed response are due to: tight dome fitment, and a small 2-3mm step? Where does the crease fit into this? I'm wrestling with Fusion 360 to design that crease, I may just take my Japanese chisels after one I have and measure the results as a quicker way to get some data.
I'm going to send another batch of designs to the printer soon, with more of the larger guides included. Also have the new Dayton RS28A on the way.
~Brandon
DriverVault Soma Sonus
Old 24th April 2018, 10:19 PM   #72
Gaga is offline Gaga  Europe
Hi Brandon,
My take of the simulations so far: Yes, no gap between the dome/suspension improves the situation - though it will probably not possible to achieve the ideal situation in real live. Still, tighten up the fitment will certainly help.
The step or crease (the 2-3mm for the simulated tweeter) helps, if we have to accept the 'gap' between suspension and waveguide throat. So far I think that the best height of the step (2-3mm in the simulation) depends on (i) the geometry, e.g. height of the dome, (ii) the size of the 'gap' and (iii) the waveguide contour. This means, that the right step height has to be adjusted to a specific tweeter (dome and suspension geometry, the existing gap to the WG throat and the specific waveguide.
Before you print new versions, could you possibly measure the exact height of the SB26ADC dome so I can check back, if my simulation was exact enough? You could simply build the step (or crease) using the existing waveguide VarC and add shims with the correct diameter between tweeter and throat, as you did before.
I'm as well not sure, if the 'step' or crease as simulated is already the best solution. May be a more smooth rounding of the edge (like done in oblate spheroid WGs) work better. I'll simulate this.
However, I think it is good to minimize the gap between membrane/Suspension and WG throat AND to start the WG contour perpendicular to the membrane.
Some simulations to look at that: First a simulation of a flat membrane without gap between membrane and WG throat in the elliptical WG VarC, with and without the 2mm 'step' or crease.
Flat membrane in elliptical WG VarC, no step:
SPL 0-60:
2018-04-23 elliptical WG VarC Flat Membr full -0mm step SPL horiz 0-60Gr 1.png
Though there is no gap between membrane and WG throat, we still see the 13kHz and 18-20kHz dips.
Does the 2mm 'step' or crease help here?
Flat membrane in elliptical WG VarC with -2mm step/crease:
SPL 0-60:
2018-04-23 elliptical WG VarC Flat Membr full -2mm step SPL horiz 0-60Gr 1.png
Note, that the situation did not improve basically, i.e. the positive effect of the 2mm step seen before, depends on the membrane geometry and gap to the WG throat.
What happens, if we use the elliptical WG VarC and simulate a membrane, which fulfills the suggested properties, i.e. (i) no gap to the WG throat and (ii) a membrane perpendicular to the contour at the WG throat?
This would look like this:
SPL 0-60:
2018-04-24 Elliptical Waveguide VarC Membran gross rechtwinklig SPL horiz 0-60Gr 1.png
Now, this looks promising. Thus I show the horizontal radiation normalized to 0 as well:
2018-04-24 Elliptical Waveguide VarC Membran gross rechtwinklig horiz norm0 1.png
Obviously, we do not have the ideal dome geometry for the WG available.
However, I'd be happy to re-check m simulations with the exact dome/suspension geometry of the SB26ADC and then adjust the best 'Step' height or crease. I'd as well check, if the crease or somehow rounded version of the step works best.
Why did the step/crease work that well for the SB26ADC simulation? I'm not finally clear with that, however, I suspect that the step (bringing the membrane 2mm back) brings the WG contour 'in line' with the emitting dome/suspension, like indicated in this image:
However, this is just a speculation and has to be evaluated still. A simulation with verified dome/suspension contour (including the angle of the dome to the tweeter faceplate) and slightly adjusted WG contour (bringing the contour perpendicular to the dome) and respective step/crease might tell...
Old 25th April 2018, 01:47 AM   #73
Originally Posted by Gaga View Post
The step or crease
Now I understand the confusion. The step and crease are different things. The crease I'm referring to is in the pic of the Revel speaker, running vertically along the horn wall. It is very slight, I hadn't noticed it before until it was pointed out.
In earlier testing I assume a wall meeting essentially normal to the diaphragm (perpendicular as you put) would be ideal, but I found steep walls to be generally better.Probably for other reasons related to wavelength vs curve radius of the wall, and whether the flare meets tangent to the baffle surface or not. I can always revisit it though with the large guides.
~Brandon
Old 26th April 2018, 02:54 AM   #74
Dave Zan is offline Dave Zan  Australia
Originally Posted by augerpro View Post
Now I understand the confusion. The step and crease are different...the crease...is in the pic of the Revel speaker...
I was also a bit confused, but could you post the picture?
Best wishes
David
Old 26th April 2018, 03:51 AM   #75
454Casull is online now 454Casull  Canada
Marked for later.
Old 26th April 2018, 05:32 AM   #76
Best wishes
David
Post #50
~Brandon
Old 26th April 2018, 06:06 AM   #77
Sorry for the confusion. I may have described things a bit complicated and unclear as a non-native speaker.
Yes, with the crease I referred as well to the image of the Revel speaker.
When I'm talking 'step' I refer to the step developing, when I set back the membrane relative to the waveguide throat (here colored yellow):
Though the Revel-'crease' is a bit rounded at the transition to the waveguide contour, I suspect that the depths of the Revel-'crease' is roughly in the same range as the 2mm 'step' used for the elliptical waveguide - and does basically the same, i.e. improve radiation.
Old 26th April 2018, 05:43 PM   #78
Here:
~Brandon
Old 26th April 2018, 06:48 PM   #79
Thanks Brandon - now I got the 'crease'! Actually did not see it...
For clarification: The tweeter is set back a bit as well in the Revel waveguide - comparable to the 'step' simulated with your elliptical waveguides.
Old 6th May 2018, 08:39 PM   #80
A series of new simulations, again around the 'step', i.e. height between tweeter membrane and waveguide-throat.
I did two more changes for this series of simulations, (i) did a slight change to the horizontal waveguide contour and (ii) refined the membrane geometry according to data received from Brandon.
The circle sector used as profile for the waveguide contour was replaced by a spline-profile in order to be more flexible during the profile optimization process to be done later. The horizontal profile used during these simulations looks like this (the vertical profile as not changed at this stage):
2018-05-02 Elliptical WG contour V2 neu SB26ADC Membrane neu V2 horiz contour image 1c.png
The SB26ADC membrane geometry used for these simulations looks like this:
The image is somehow self-explanatory. The 'step' (yellow) is varied from 0mm to 5mm.
A summary of the simulations is given in the next image:
Images at the left side show horizontal radiation normalized to 0, images at the right side show the SPL at different angles from 0 to 60 in 10-steps for steps from 0mm to 5mm.
Again - as simulated for the elliptical waveguide typeC with the somehow simpler SB26ADC membrane geometry before - the 2mm-step seems beneficial for a smooth (although not real constant) directivity.
More on waveguide-throat variants and phase-shield / phase-plug variants later.
Open source Waveguides for CNC & 3D printing!Hide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 02:31 PM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 03:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 02:21 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
UK source for Waveguides for tweeter (or how do DIY one)? Puggie Multi-Way 3 22nd June 2005 04:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
