Placement of Diffusors
Thread Tools
Old 8th December 2016, 03:50 PM   #1
POOH is offline POOH  United States
POOH's Avatar
Default Placement of Diffusors
I recently picked up 12 Auralex T'Fusor panels.
My room is 14.5 wide by 23 deep and my horns are pretty much butted up against the side walls firing down the long end of the room. The primary listening area is six feet out from the back wall. The system has pretty much controlled directivity down to 200 Hz and is mostly around 60-80 degree radiation.
Where do you recommend I start experimenting with placement of these panels?
I'm thinking of using a few of them behind me on the back wall.
Auralex Acoustics | T’Fusor? 3D Sound Diffusor
Old 8th December 2016, 06:12 PM   #2
AllenB is offline AllenB  Australia
AllenB's Avatar
Not easy to suggest blind. I think the reverberant field should be diffuse. On one hand the speakers should be initially contributing to that. If there is a problem with the near walls that might seem like a good place to diffuse but it's debatable that this should be happening in the first place so the rear wall seems the safe place. I've seen them in the first half of the room but they would have to fit in with your early reflection goals. I would be considering their working range and decide what places want diffusion and what places want absorption.
Old 8th December 2016, 07:23 PM   #3
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
If your speakers are very directional and pointed a little inward toward you, try putting the diffusors behind you and to the sides a little so that they catch the waves that fly past you and reflect it (delayed and diffused) back at you. I have that arrangement and it works well for me. Tried them on sides and in front between the speakers, but those didn't work as well (though maybe looked a little better!)
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 8th December 2016, 07:51 PM   #4
POOH's Avatar
Thank you both.
bwaslo- are you saying catching the waves on the adjacent side wall behind me from the horn radiating from the opposite wall? That sounds like it might open things up. I will try this this weekend.
Old 8th December 2016, 08:47 PM   #5
bwaslo's Avatar
Yup. But try to get the delay as long as you can get it (move the diffusors as far back as possible)
Old 8th December 2016, 10:41 PM   #6
frangus is offline frangus
Not sure if it was placebo, but I seam to hear "problems" when placed behind and to the side of the head. But i am very close to the back wall so the diffusors are close
Scattered on the front wall (behind speakers and in centre) works well for me particularly where the upper bass and low mids spread around to the back and reflect directly off the panels. I spread the panels and sit them a foot forward of the wall to try to diffuse some of the bass frequencies as well
The first reflections from the floor works too but it is impractical
Old 8th December 2016, 11:50 PM   #7
wesayso is online now wesayso  Netherlands
wesayso's Avatar
POOH, this might be a good idea if you have the space:
Source: https://www.gearslutz.com/board/stud...ning-room.html
Jim set it up like that to control the timing of it as a true Haas kicker. By bouncing it off a second panel the diffused sound arrives as late like it would in a bigger room. He has it timed at ~24 ms after the mains:
(as measured with the Demo version of APL_TDA software... You see the Haas kicker firing at 24 ms.
Use Science to design your speakers and they will sound like a piece of Art...
Old 9th December 2016, 01:48 AM   #8
POOH's Avatar
thanks again for all the advice. looks i need to read that thread and start experimenting
Old 9th December 2016, 08:36 AM   #9
Very interesting. Will have to read through that thread. Not sure how he was able to focus the reverb so tightly around 25ms...
Old 9th December 2016, 09:07 PM   #10
Omholt is offline Omholt  Norway
Omholt's Avatar
Your products are probably more scattering units than proper diffusors. And they aren't deep enough to cover much freq. area.
Generally though, diffusion works best where you have late arrival reflections.
Placement of DiffusorsHide this!Advertise here!
Thread Tools
Wide polar pattern speakers via Diffusors noodle_snacks Multi-Way 6 11th May 2012 08:47 PM
CCS placement dgta Tubes / Valves 17 11th July 2011 05:10 PM
Placement lpd Planars & Exotics 0 21st August 2008 12:39 AM
sub placement chainenoble Subwoofers 3 13th October 2006 04:45 AM
Diffusors in enclosures? walker Multi-Way 6 29th November 2001 09:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
