The XBush Mark 2. A synergy/Unity horn of spherical proportions
OK chaps, I have managed to cut away a little of the sphere's lip to allow a baffle of up to 18mm thickness.....
So what would people pick if they had free choice of a cld sandwich 18mm thickness?
I was thinking 3mm aluminum top layer, 3mm 80 shore nitrile rubber sheet then 12mm MDF, might make a nice cld baffle???
I'm not a physics expert, but as I remember, Earl Geddes (who is) said that CLD is most effective when both outer layesrs are the same and the inside layer is a thin-as-practical lossy medium. He used to use a layer of "Melamine Glue" as the inside, but now uses some proprietary goop. When I made a CLC cabinet some years back it was half inch mdf on the outsides and the Melamine glue between. Worked well as far as I could tell, very dead cabinet. Got the Melamine glue from Grainger. The MDF is nasty stuff to work with (guessing you already found that).
Thanks bwaslo, I think I better do some research, as I am going to great lengths with these spheres to maximize engineered properties.
Just ordered some 4mm silent coat buytl mastic sheets for the inside. Then 18mm 100% wool underlay.....so I want to get the baffles right.
OK.
Lots of reading up and looking up various sheet composite damping values, transmission factors etc.
I have decided to combine a CLD composite baffle, with a 'floating isolation' or 'decoupling' technique.
So I am going to make a 3mm aluminium/6mm MDF/3mm aluminium CLD baffle ring - looking at the various charts - they agree with bswalo and Geddes that same thickness constraining layers (3mm aluminium) with double thickness 6mm MDF in the middle appears to produce excellent damping and low transmission factors. This will give a combined thickness of 12mm and should be very stiff and well damped.
Then this will be isolated with a 3mm sorbothane gasket - looking at the literature on sorbothane - they advise against glueing it on both sides- i.e. they don't advise using it as CLD - more as a damping decoupling layer.
So I am hoping a well damped, stiff, 12mm al/MDF/al baffle, floating on 3mm sorbothane will have the best of both worlds.
I will use over-sized holes with rubber washers to ensure no 'shorting' of the isolation via the bolts to the enclosure.
OK.
I can attest to the effectiveness of sorbothane.
I used a 1/8" sorbothane layer sandwiched between an 18 mm baltic birch baffle and an 18 mm BB driver mounting plate. The baffle was rigidly braced by the horn flares that formed the slot that loaded the woofer. The driver mounting plate was free floating as the mounting bolts are isolated with rubber washers. The driver has a thick rubber gasket which partially isolates the driver from its mounting plate. The woofer is an AE TD15H, 14mm Xmax. When pounding bass you feel nothing on the front panel but if you open the box and touch the driver mounting plate, it "thrumms" against your fingers.
Right aluminium discs and MDF cut to size. Laminated up after lots of cuts and sanding.....
So what happens if you take one heavy gauge peony plant support, turn it upsidedown, angle grind off the legs, and spray it black......? 😁
Nice work with the plant support. How does your wife feel about you taking her plant support frame? Is it rigid enough to support the weight of the speaker fully loaded with woofers?
She was initially very pleased I had thought of her......:eek:
They are made from 8mm steel rod, and because of the three circles and five supporting legs are actually very strong - I can happily sit on them!
They will need isolating from the globe though - so some sorbothane rings are being cut.
Are you making brand new wave-guides or are these the old ones? I don't see the drivers attached or the glued on bondo woofer adapter plate.
These are the old ones stripped down. Once I have mounted them on the alumium baffles I will be sanding back the overhang on the corners and making a nice smooth transition.
I think I will paint the baffles matt black - a shame to loose the aluminum, but I think it will help the horn blend into the circular baffle.
Founder of XSA-Labs
Joined 2012
Nice work! There may be spherical resonance mode that will cause a small peak. But if you have enough damping and things to break up that mode it should be ok. I noticed a small peak on a small hypercube enclosure which resembled a sphere. If you can have a brace inside to break that spherical symmetry it will help.
Thanks X.
There should be no mode, due to the horn which essentially cleaves the volume in half like a giant central wedge. Combined with the angled woofers the internal volume is actually not a sphere at all!
If I had mounted the driver flat on the front baffle as is usual, there would have been modal issues!
