Simple High Performing Headphone Amp
So after gathering dust for several weeks, I finally completed my though-hole version of this awesome amp.
Dead quiet, kickass bass and excellent dynamics. DC offset is around 5mV on the left and 7mV on the right - pretty decent.
Thank you TimS and XRK!
Hi Donthertzme,
Nice through hole boards. Any chance you can share the PCB lay out!
Founder of XSA-Labs
Joined 2012
It’s a public design so you can post if you want. But if folks want a ready-to-build version that has a low noise PSU already, check out the JPS64 layout over in the GB thread.
Simple High Performance DC Coupled Class A HPA with sub PPM THD
699591d1535270403-simple-performance-dc-coupled-class-hpa-sub-ppm-thd-shpa-gb-build-01-jpg
Here are the Eagle layout files. I've included 2 versions - the one you see in the picture (100 X 85mm), and one with more readily-available standard SK104-style heatsinks (85 X 85mm). Let me know if you'd prefer gerbers.
I left out the power supply so I could try various power options. But JPS64's complete version is also very good.
  • TimS XRK HPA mono.zip
