GB - ACA Power Supply Filter Kits
I'm posting the gerber files plus the build docs I sent with the group buy shipments. If you've never made a run of PCB's before, you can compare pricing at:
https://pcbshopper.com/Out of habit, I end up going for https://jlcpcb.com/ every time. With DHL shipping it's typically about 10 days from submittal of order to arrive at my house.
Chances are you'll end up extra boards. For example, you'll need 1 or 2, but you may need to make a minimum run of 5 or 10 boards. Please offer up the extras to other users. I'm reasonably sure you'll sell them off in short order.
There are 2 types of boards. Make note of which one before you run the boards.
The standard board for a single SMPS brick (98% of builds?) - Filename: RT ACA PSU Filter PCB Gerbers.zip (this post)
Dual SMPS version (2% of builds?) - Filename: RT ACA Dual SMPS Filter PCB Gerbers.zip (next Post)
The good news is that if you make a run of the Dual SMPS boards by mistake, you can turn it into a standard board with a few scraps of wire for jumpers. Going the other way is not so simple...
Enjoy! Happy building!
Randy -
I'm a happy new user of your single SMPS RT ACA PSU Filter board with my newly running amp as of yesterday.
Question: if I wanted to run a second brick in this stereo amp, may I build another complete single filter board (I ordered two from you originally) and run one each as is per each brick, and simply leave one V+ to amp on each filter board detached? I ask noting your post above where you said 'Going the other way is not so simple'
Thanks in advance,
Jim
