Not supercritical. Just note the physical size and the lead spacing. You may have to bend the leads a bit. Electrically your choice of 210uH is a little more inductance (so just fine), and 4A is a little lower current rating, but plenty for the circuit (so also perfectly fine).
I was just wondering if you still happen to have a couple of pcb's hiding out there, without a home?
Thanks ….I will breadboard the circuit first and give it a go.Not supercritical. Just note the physical size and the lead spacing. You may have to bend the leads a bit. Electrically your choice of 210uH is a little more inductance (so just fine), and 4A is a little lower current rating, but plenty for the circuit (so also perfectly fine).
See posts # 136 & 137I was just wondering if you still happen to have a couple of pcb's hiding out there, without a home?
I am just wondering if I could use (On the ACA PSU Filter PCB) for C2 and C3 a 1000μf 35V instead of 50V?
I am using exclusively only the 24V PSU.
If possible I would like to buy option A. If not available then option C, or placed on a new order list?
Thank you!
Thank you!
Absolutely - I think that's a typo on the schematic. I shipped the kits with 35V IIRC. So by all means, 1000uF 35V.I am just wondering if I could use (On the ACA PSU Filter PCB) for C2 and C3 a 1000μf 35V instead of 50V?
I used the same series of caps that were called out in the store's P089ZB kit. Nichicon UHW or Kemet ESH series.
Thank you for your reply, I was just checking just in case there was a reason for 50V.Absolutely - I think that's a typo on the schematic. I shipped the kits with 35V IIRC. So by all means, 1000uF 35V.
Thank for your design and for sharinmg the Gerbers with us.
Bambos
Hi folks,
Is there a consensus among members who've installed the filter as to what the sonic improvements are? I've discovered a slight vocal sibilance audible with some tweeters and am wondering where the source is. The Meanwell brick, coupling caps or something else? I have the v1.6 running in stereo mode.
Thanks,
Glenn
Thanks,
Glenn
@ripblade
You’re a prime candidate to try it and report back. I have mono blocks with the filters installed and honestly I can’t tell a difference. However, I didn’t have a problem I was trying to address, you do. All that to say that I do have extra kits available (I ordered for future projects) and would be willing to send you one. PM me if interested.
@ripblade
I'm definitely interested, Kevin. I'm not sure how to contact you directly. Is there a minimum post count I need to fulfill before I can do that?
I'm not sure I even understand the instruction given here:
Do I post the request here is or is there a dedicated thread for starting PMs somewhere?New members who are still under moderation are not allowed to send private messages. Also known as "Start a conversation."
This is to prevent spam by private message.
If you need to contact a forum member about a group buy, or an item on offer, you can post in the thread to request a PM. You will be able to read an reply to that PM.
Once a member has cleared moderation, starting PM will be available.
https://www.diyaudio.com/community/...ot-send-private-messages.384831/#post-6986646
Every time I get used to something they change all the rules.🤣
Just tap the username at the top of my post. You should get a box with my info and then at the bottom there’s a button for “Start Conversation”.
Ah, ok....that button wasn't there a couple of hours ago when I visited your profile page several times looking for it....
I just ordered some boards with another PCB order. Send me a private message if you are interested. I'm not doing the kits this time, just the boards.
Kits, no. But I have boards on the way from the PCB fabricator arriving later this week. Send me a private message if you want any.
- Group Buys
- GB - ACA Power Supply Filter Kits
