Hi Dan K,
Yes, plenty to go around. only 2 would make it appear that shipping cost high as compared to pcb cost. But its upto you.
please PM me paypal email, complete address, and will send you a paypal invoice.
once payment is done , packet will be shipped.
regards
prasi
regards
prasi
about the mosfets, again
I know your suggestion works, as do the other...
Excuse my stubbornness, but I'm trying to better understand the matter.
tvicol also kindly explained (shorted down):
SUP70060E has better Qg Gate Charge Total, but
IPP029N06NAKSA1 has better Rdson
Would you still select SUP70060E? (is Qg Gate Charge Total more important)
Many thanks
david
Very important, Rdson must be as low as possible at 10V. Best under 10mohm.
Very important, Qg Gate Charge Total at 10V as low as possible.
Many thanks
david
Vds is only 60v for the ipp part.
Selection depends on 4 things
Vds,
Vgsth
Qg
Rdson
Cost
Availability
Not in any order of importance.
Tvicol has posted some guidelines towards the beginning.
Take a good look at different mosfets.
Rdson makes a difference on how much heat is generated.
Qg is critical for working.
Vds for higher magin of safety.
Go through the datasheet to better understand and for some calculations
Vds,
Vgsth
Qg
Rdson
Cost
Availability
Hi Dave,
Just connect the V+ and V- of the LT4320 tht to the CRC .
You can connect the transformer secondaries to THT LT4320 directly.
If you are planning to use the snubber components, provision is already made for SMD snubbers under the THT LT4320 under AC tabs.
Though what you have shown seems to be correct, but leads to too much wiring.
Hi Dave,
Doh, Like this?
I thought the jury decided not to use snubbers?
yes, the connections are correct.
Just use them without snubbers.. you will notice definite improvement as reported by many diyers.
Thanks mpa.
To others,
unfortunately I have run out of THT rectifier boards (consider yourself lucky , if you find some extra boards in your packet, a christmas gift).
SO wont be able to ship any new payments made today onwards until a month.
So members "flamethrower1" and "powersuppe" will have to wait for a month.
I will have plenty of stock after a month.
plenty of smd's and a few crc-lt4320 to go around.
regards
prasi
LT4320 RECTIFIER AND LT4320 CRC PSU GROUP BUY - Google Sheets
To others,
regards
prasi
Yours is shipped today Mr. Dean. check the list now.
- Group Buys
- LT4320 based active rectifier
