I might well want a second!
If you want I reduce mine order to only 1 unit, please let me know?
GB for Saligny HV;
nautibuoy - 2 Saligny HV
Jazid - 2 Saligny HV
ste - 1 Saligny HV
Luca72c - 2 Saligny HV
Rinman77 - 2 Saligny HV
merlin el mago - 2 Saligny HV
Total = 11
If you're interested copy and paste the list to a new post and add your name and requirements to the bottom of the list.
ste - 1 Saligny HV
Total = 11
No problem Felipe.
We can leave this open for a while to see if there is any more interest and we can sort out payment, distribution etc. closer to when Tibi can supply.
GB for Saligny HV;
ste - 1 Saligny HV
merlin el mago - 1 Saligny HV
Total = 10
GB for Saligny HV;
ste - 1 Saligny HV
Total = 10
Are you still planning on building a higher voltage version for tube amps?
High voltage and low Rdson mosfets are very expensive, far more expensive than many tube rectifiers. Beside this, tube people like tube glow and "soft recovery".
Sorry, but my answer is no.
Tibi
...tube people like tube glow and "soft recovery".
I plan to use the Saligny HV in front of a CLCLC power supply for an SE-OTL tube amp project.
Well, give me 1000 people like you, so I can justify such project.
Tibi
I don't think I'll be much help Tibi, my B+ requirement is only around 160V.
Tibi
I woul be 1 more
Tibi
Hi Tibi,
I was looking at your EvoTtronix website and you seem sell the low current version is that correct? The site says minimum order for EU is 10units, is that correct?
I am in the EU and I need 4 maybe 5. At a later date I need 2 HC versions. I am really waiting for these unit’s
Please note that Saligny will work with center taped transformers (and center taped used as main reference ground) only when both sections are in phase. This was discussed here.
Thanks to a very observant friend who noticed the frequency of ripple, the mystery shrouding the weird synphase connection has finally been revealed
It is perhaps worth warning any adventurous synphasers that in this mode the 4320 works as a parallel half wave rectifier with the obvious increase in ripple. It may be appropriate for this info to also find a spot within the first post of this thread.
The 50Hz ripple can be seen in both simulation and measurements.
In the standard unipolar connection the 4320 applies out of phase control signals to the opposing fets in the bridge, emulating the behaviour of a standard diode bridge. In the synphase connection this changes and the opposing fets get synphase signals at their gates, effectively working in parallel.
Below is the 50Hz ripple waveform from the synphase simulation. In the standard connection this is of course 100Hz.
On the plus side this is an elegant way to achieve half wave rectification without passing dc through the transformer secondary.
GB for Saligny HV;
ste - 1 Saligny HV
nightsky -2 Saligny HV
s610adam - 4 Saligny HV
Total = 16
Updated, almost lost track - my thread update emails stopped happening
ste - 1 Saligny HV
Total = 16
- Group Buys
- Ideal bridge rectifier GB
