Riy,
My reply to your email is bouncing back as undeliverable.
dave
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
dave
hm, very weird. I will send you the same from another address, let's see if that worksMy reply to your email is bouncing back as undeliverable.
Alright, the speakers are built and are standing next to some Voigt Pipes. I've been letting them play for about 20 hours now.
With the Voigt Pipes it took about 2 weeks of much use and suddenly over the course of 1-2 days their sound changed quite noticeably, their sound became much fuller and resonent.
I'm wondering if that will be the case with the horns as well, or if their sound will roughly stay the same.
alrighty, then I'll keep flipping the coin while listening to themThe simple answer is that the bigger the vent the greater its acoustic pressure modulating the driver, but with two such different designs it would take a lot of math to figure each, so 'flip a coin' .
I mainly listen to music via a computer/steaming-device, so I'm able to play around with some Equalizer-software (it's called Equalizer Apo, i have the Peace-UI) and boy, does it enhance things. I'm liking the Horns more and more. Nice and punchy, much more dynamic than the Voigt Pipes. Although I have to admit, I also like the Voigt Pipes for their clarity and full-ness.
As the latin saying goes "varietas delectat", "variety delights you".
While I'm sitting here, I alreayd have a new idea floating through my head about a modified inverted BIB speaker. Should I create a new thread for it or ask to re-open the iBIB-thread?
Dunno, but so much has been published already that doing both a thread and google search seems the first thing to do and go from there:
https://www.google.com/search?q=inv...iBBiwA-IDBBgBIEGIBgGQBgM&sclient=gws-wiz-serp
https://www.google.com/search?q=inv...myCC4QrQIoBHoECBoQBQ&biw=1242&bih=568&dpr=1.1
- Full Range
- Spawn of Frugel-Horn
