What do we know about the W6-1914SB? I ran across this 6in honeycomb diaphragm neodymium motor midrange today. I looked at the response curve and it seems wide and flat and with decent sensitivity. I think it won’t make much bass but could be a good top for a FAST/WAW.
Data sheet:
https://www.parts-express.com/pedocs/specs/264-905--tang-band-w6-1914sb-spec-sheet.pdf
Code:
Resonant Frequency (Fs)70 Hz
DC Resistance (Re)6.5 ohms
Voice Coil Inductance (Le)0.073 mH
Mechanical Q (Qms)7.19
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)0.39 ft.³
Mechanical Compliance of Suspension (Cms)0.399 mm/N
BL Product (BL)10.23 Tm
Diaphragm Mass Inc. Airload (Mms)13.97g
Maximum Linear Excursion (Xmax)0.5 mm
Surface Area of Cone (Sd)140 cm²
Data sheet:
Is it the high price that’s keeping folks disinterested in this driver?
$139 is not all that high for something with a wide and flat bandwidth like this. Cast aluminum frame, neodymium magnets, high tech composite honeycomb diaphragm, etc., make for a more expensive than usual full range.
Tang Band W6-1914SB 6" Sandwich Cone Midrange Driver
A 1.5L sealed rear chamber allows F3 of 180Hz. Perfect range for a FAST.
It’s been called a poor man’s Accuton midbass.
