A Speaker that Kicks Butt in Large Spaces
tying the front and back to the shelf might be sufficient. I had a cheap Warwick bass combo amp whose MDF flexed a lot and it was functional.
Using 1/2" material would be 14.6" wide by 21.5" high going by 0.65 * K15's internal dims
Founder of XSA-Labs
Joined 2012
hey X - I've got a mini K15 for an 8" which might hold a 10" - could one get a rough idea of performance in that case where the front of the cone sees an ~7" diameter cutout? have to be careful not to let B102's cone slap against the baffle (IF it will fit the rear chamber)
Not sure what your question is... You have a K15 scaled down to 8/15 (0.53x) and you want to put a 10 incher (B102) in it?
If that is your question, here is what you get:
Usable to 80Hz, needs a sub below 80Hz.
its 1/2" plywood, this size: 1.4 cubic foot external bulk at 18.625" H x 13.5" W x 9.625" D (sans molding) and is cutout for an 8" - can I get a pretty good idea of how it would perform with proper cutout for a 10" by rear mounting a 10" speaker over the ~7" diameter hole? do you predict good power handling with Delta10a or B102 in 0.55 to 0.65 size K? (got 1kw/c) - -would a 2X10" Karlsonator be a good project with regards to range and power handling? or does it get too tall/long? - (two 2.5" to 3" coil should do pretty well.)
oops -the external dims are ~18.7"H x 13.5"W x 11.5"D for ~1.7 cu.ft. external bulk and B102 fits pretty well centered over the existing cutout - got to dig for a camera. The plywood in this old cabinet isn't as stiff as modern 1/2" Baltic birch. If it really could hit 80Hz with power then would be a good substitute for larger front load horns. I'm pretty sure ~0.65 scale will do 80 with Delta10A. Sometimes its easier and better to add a sub or two than try to extend some drivers LF cutoff. That recent TQWT with 1260W Infinity is liked by TheJessMan.
the speaker which came with this little diy K was a weak motor Stromberg-Carlson
with a thrown together mismash of 1uF to a CTS KSN1005 helper tweeter w. 28R shunt, the new model of B102 does pretty well - drums have real visceral kick without even 1/16" peak to peak excursion - maybe better than some front horn such as my 100Hz hypex - its got promise in this tiny form factor - the old mahogany plywood cabinet is flexy and tweeter not optimum - a good sub or two and this might be a pretty good system for realistic spl in a small package. btw, the cutout for the 8 is such as it just barely hides B102's surround.
for those who want real dynamics and are willing to experiment, Karlson enclosures offer a good alternative to direct radiator and horn
hey X - what are some of the best small drivers for wide dynamic little K work? I've one Delta Pro8A - although it shows strong in the graph below, its less sensitive than a F6 L.Cao - but the Eminence will take more power - there should be some strong 10" - I want realistic drum sounds in as small of a package as possible (combined with a sub) at 18.6x13.5x11.5", my little K15 type even with the weaker/new B102 is impressive in its range.
Delta Pro8A in SK8 vs F6 L.Cao in a Karlsonator6 prototype - perhaps SK8's curved reflector and (small area) port are contributing
to the large spl variation
for a 4ohm driver, MCM has a good price on a Faital Pro 10" - its only rated 300W but that's not shabby - how does this look to you? The amp I bought recently is optimized for higher loads - rated 1K@8/1.3K@4ohm
I have some SN10 P-Audio 10" coax unused which might make pretty good little midbass Ks
Faital Pro 10 Inch 300W 4 Ohm Mid Range / Mid Bass Speaker | 10PR300C | Faital Pro
Faital10
my P-Audio 10cx IIRC has a bit stronger motor than spec and being neo, is pretty light
Here's SN10C's pdf http://bjl.audioconcept.free.fr/Archives/03_Caracteristiques_HP/P.AUDIO SYSTEM/SN SERIES/SN-10C.pdf
do you think it would work in this small K?
coaxial speaker
diameter in / 10/254 mm
Power RMS (W) 200
resistance (ohms) 8
resonant frequency Fs (Hz) 67.3
Sensitivity 1 W / m (dB) 94
overall quality factor Qts 0,455
equivalent volume Vas (l) 27.2
maximum displacement Xmax (mm) 2.8
Frequency range (Hz) 65-20000
diameter of the coil (in) 2,5
neodymium magnet material
HF driver (in) 1
Weight (kg) 3.1
here's SN10C's woofer graph - extremely blurry but believe the 94dB/1KHz sensitivity helps mark its window
it has a rise similar to Delta10A
SN10C coax
Delta10A
thanks - that might be enough - is a bit larger any more useful? - does power handling of the 0.55 size look good?
how much sub would you say is needed to subjectively balance out a little 0.55 scale pair?
Delta10a looks pretty strong
compared to the moderate strength motor coax, SN-10C
100Hz might do -besides a pair of SN10C, I've a pair of Delta10A, one new spec B102, 2 old 10G200, and maybe 2 new Beta10cx- a good sub would be needed - - what might one make which is reasonably compact to keep up with the little Ks and reach say 40Hz?
how far downwards does the cusp aperture shift tuning?
Founder of XSA-Labs
Joined 2012
for a midbass module in a full horn system, RCA-Fan's Hypex70 could be used instead of a Karlson-coupler
but for impact and small size, I prefer K to horn.
what scale K15 looks best for Kappa12A? -
Thiele-Small Parameters
Resonant Frequency (Fs)45 Hz
DC Resistance (Re)5.41 ohms
Voice Coil Inductance (Le)0.77 mH
Mechanical Q (Qms)7.76
Electromagnetic Q (Qes)0.28
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)4 ft.³
Mechanical Compliance of Suspension (Cms)0.3 mm/N
BL Product (BL)15.2 Tm
Diaphragm Mass Inc. Airload (Mms)42g
Maximum Linear Excursion (Xmax)3.2 mm
Surface Area of Cone (Sd)519.5 cm²
for already made bass, I can use a Stereo Integrity SI15D2 bandpass box
