No over sampling (a bypass)
There are already plenty of true believers to help you with that.
Not everything the "industry" invents is bad...
... but manufacturing ease and cost weigh more than product quality.
I ambrace it if it is done correctly ! So , you have one that is not cheap or do have none at all ? I guess the second as you are not willing to spend money on it even if it was done correctly. But you already “know” that this unit does not exists as you are “allknowing” in these matters.
Hi, finally tried today on an old Philips CD373 that I have and although its early days, id say it did indeed sound better and more defined/spacious than simply using the coax output into my DAC
Once my clock arrives for the Marantz ill fit the clock then try this after a few listens.
Thanks for the help.
Found a nice new toroidal and made some pcb's with bridge rectifiers and 5v regulators for supply to dac, clock, saa7220 and 7210
Is it worth installing the toridial as its tight but possible or just stick with powering the regs from the current supply?
is it worth the effort for what will be gained if anything?
- Digital Source
- Marantz CD273
