Building the ultimate NOS DAC using TDA1541A
Thread Tools
Old 10th June 2021, 09:56 PM   #7811
weissi is offline weissi  Europe
Use the CPLD board from China.
servus
Old 10th June 2021, 11:44 PM   #7812
diyiggy is offline diyiggy
diyiggy's Avatar
I can sold one IanCanada I2StoPCM v1.1, I have three brandnew. (works with tda1540, simultaneous mode TDA1541, AD1862,1865,PCM1702, 1704
but it must be slaved by a master clock with uf-l : made to work with Iancanada Masterclock or later FifoPi... all i/o are uf-l
Pi VII au bord du Pô.
Old 11th June 2021, 06:46 AM   #7813
lcsaszar is offline lcsaszar  Hungary
My plan is to use that board. Actually I am looking for the DAC board itself. My goal is a dual 1541 board where each DAC operates in balanced mode (L+/L-, R+/R-), accepts simultaneous offset binary, and perhaps there are onboard shunt regulators. OK, maybe I will design it, or just link the components together on a veroboard.
Old 11th June 2021, 09:07 AM   #7814
jonclancy is offline jonclancy  United Kingdom
Originally Posted by lcsaszar View Post
Congrats, later you'll have even less time
I am also looking for a I2S to dual simultaneous TDA1541A PCB to be assembled DIY.
Thanks! Don’t I know it!
I’ll check out the boards. I have built Pedja’s DACs (an Aya is still in my system doing sterling service today), and was looking to see what else there was out there with two chips. John’s suggestions in this thread really piqued my interest.
John Linsley Hood Ripple Eater GB Part One made £729 for Cancer Research UK. Thanks for your support!!!
Old 11th June 2021, 12:42 PM   #7815
diyiggy's Avatar
Philips 7220 was not a jitter contributor ? Myth ?
Old 11th June 2021, 12:57 PM   #7816
Not with proper reclocking and PSU filtering.
Old 11th June 2021, 01:17 PM   #7817
diyiggy's Avatar
cool . Thanks.
I have tons from my broken cd players (aka Lampizator disease illness)
Old 11th June 2021, 01:32 PM   #7818
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Who doesn't Building the ultimate NOS DAC using TDA1541A
Old 20th June 2021, 06:29 PM   #7819
L0rdGwyn is offline L0rdGwyn  United States
L0rdGwyn's Avatar
Hello - I am in the very preliminary stages of a TDA 1541A design. I have read good things on Sowter 1465 I/V interface transformers. Anyone has experience using them? They are meant to generate a line-level output with a high-value resistor across the secondary, however seems one could use a lower value resistor and present the TDA 1541A with a smaller load at the cost of output voltage and add a gain stage to the secondary, I'm curious if anyone has experimented with both configurations, thank you
Old 21st June 2021, 02:23 AM   #7820
diyiggy's Avatar
Many tested and man came back to active I/V . There is no real evidence this (and other) transformer is the best at this job. This is not it's bad, it's just there is better for this chip.
Seing your avatar, I would try a tube for the I/V task (Thorsten Loesch) .
Building the ultimate NOS DAC using TDA1541AHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
