Valve DAC from Linear Audio volume 13
Thread Tools
Old 29th March 2021, 08:38 AM   #1541
acg is offline acg  Australia
No worries Marcel, I've not managed to get to turning it on just yet. Am struggling to get all my work complete before the Easter holiday...may not be for a little while yet.
Thanks for letting me know.
Anthony
Old 5th April 2021, 03:55 PM   #1542
Tix88 is offline Tix88  Italy
Hi, anyone interested I have a pcb kit available for sale.
Old 21st April 2021, 11:44 AM   #1543
SonnyMarrow is offline SonnyMarrow  United States
What is the best point to attach to chassis ground? I'm using a ground loop breaker and connecting to the chassis at a single point.
Old 21st April 2021, 01:26 PM   #1544
MarcelvdG is offline MarcelvdG  Netherlands
I didn't have that issue with my wooden enclosure, but it's probably at the analogue output.
That is, I would tend to connect all balanced in- and outputs according to AES48: XLR pin 1 straight to the chassis and one point of the chassis to the circuit ground. For that last connection I'd take a point close to the analogue outputs and connect it to the ground pins of the output connector of the filter board.
Do you have any unbalanced inputs, such as S/PDIF? I think I kept my S/PDIF inputs completely insulated with an insulated cinch connector and a transformer right behind the connector, but I can't check if I remember that correctly right now..
Old 21st April 2021, 02:12 PM   #1545
My initial plan was to wire pin one of the output XLRs to the ground of the filter PCB, then from the filter PCB to the ground loop breaker. Can the jacks be connected to the chassis directly and not the star ground? I had a concern with this method because my case will likely be powder coated.
Old 21st April 2021, 02:39 PM   #1546
I think your initial plan should also work. How do you want to make contact with your powder-coated case?
The idea behind AES48 is to let the shields and chassis form one big Faraday's cage, to take for granted that there may be ground loops, but to ensure that the current in those ground loops doesn't flow through any internal circuitry (which is often unbalanced, even in professional equipment). It's an approach that only works with balanced inputs and outputs, but it results in better RF shielding than pure star grounding.
Old 21st April 2021, 03:15 PM   #1547
Ok I think I'm almost ready to turn on the DAC for the first time. Right now I only have optical input setup. Before I flip the switch, I had a question about using a DC power supply for the 6.3v. Do I just connect the positive and negative to pins 3 and 4 of the power terminal? I was going to connect the positive to 3, where I jumped the THT.
Old 21st April 2021, 03:41 PM   #1548
Well, first test boot was unsuccessful so I quickly turned it off.
All PSUs, including the on-board 5V supply, are working properly. When I turn on the DAC, the tubes begin to light/heat up, but the clipping light is on and none of the other indicator lights work. I have switch 3/C on the FPGA set to on, so the lights should be on even if not using surprise. I also quickly tried surprise to see if that would change anything and it did not.
Could it be that I flashed the FPGA before shorting the resistor pad on it?
Old 21st April 2021, 04:20 PM   #1549
Does the 85A2 light up and if so, immediately or after a few seconds? When does the clipping lamp turn on?
It shouldn't make any difference whether you programmed the FPGA module before or after shorting the R102 pads.
Old 21st April 2021, 04:23 PM   #1550
I will double check the 85A2, but it seemed to light up immediately. The clipping lamp (using an LED) turns on immediately and stays on. I have no inputs or outputs connected, though the filter board is connected to the DAC.
Valve DAC from Linear Audio volume 13Hide this!Advertise here!
Thread Tools
13.8V 80A Linear PS circuit design analysis for Ham Radio Use FJHookah Power Supplies 71 27th October 2019 02:52 PM
Is it tradition that we use linear PSUs for valve amps? Paul Uszak Power Supplies 9 2nd September 2016 10:58 PM
Audio Valve Eklipse volume pot value? Ki Choi Tubes / Valves 0 27th March 2015 05:22 PM
Londog Audio VDt1 Valve Output 24/192 DSD DAC mainscablesrus Mains Cables R Us 1 1st October 2013 06:52 PM
Audio Note DAC 2.1x valve DAC juancho Swap Meet 0 6th July 2005 09:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
