Valve DAC from Linear Audio volume 13
Thread Tools
Old 14th February 2021, 10:00 PM   #1471
SonnyMarrow is offline SonnyMarrow  United States
Tried without the area constraints. Took much longer, still spit out some errors. Thinking I should cancel my order and just wait it out till Trenz gets more LX75 in stock.
Old 14th February 2021, 10:09 PM   #1472
MarcelvdG is online now MarcelvdG  Netherlands
I'm afraid you are right, this looks like it is not going to work without redesigning for a lower FIR clock frequency. Can you still cancel the order?
Old 14th February 2021, 10:15 PM   #1473
The order hasn't been processed yet, so I emailed them to cancel. Shame. When I first ordered the LX75-based one, it said March, then got pushed back to late September. I think in the interim, I will build the DSD-only version.
Old 16th February 2021, 02:06 PM   #1474
Confirmed with Trenz that they are having a supplier issue, so September/October is likely the earliest the LX75 will be back in stock. Sucks that the AKM fire derailed the Simple DSD SRC group buy, because that would have been perfect for the DSD-only version. I'll have to become acquainted with HQplayer.
Old 16th February 2021, 03:32 PM   #1475
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
If you want to try without the outlay for HQP in the first instance you might checkout Daphile - IIRC it does PCM to DSD conversion, though not supposed to be as good as HQP - might be sufficient to get you started?
Old 16th February 2021, 03:53 PM   #1476
Markw4 is offline Markw4  United States
HQP is offered in free trial format. Don't know about the latest version, but for the last version it limited playback to 30minutes at time. One could restart it immediately after it timed out. It was just annoying to use that way for more than some listening tests.
Old 16th February 2021, 05:35 PM   #1477
nautibuoy's Avatar
The outlay for HQP isn't just the software cost, you need a pretty meaty computer too! I believe Daphile has much lighter hardware processing requirements.
Also, I think the trial version of HQP stops working at the end of the period though I admit it's a long time since I haven't had a licensed copy.
Old 16th February 2021, 05:40 PM   #1478
I have a 5900x, so I think I'm good with HQPlayer if that's the route I go.
Old 16th February 2021, 05:47 PM   #1479
nautibuoy's Avatar
Nice, benchmark of nearly 40K - that should cope nicely.
Old 16th February 2021, 05:53 PM   #1480
rfbrw is offline rfbrw
If you just want play DSD files on a PC Teac HiRes editor will do that. It will also convert PCM to DSD albeit not on the fly.
This might also be of interest PCMDSD
Valve DAC from Linear Audio volume 13Hide this!Advertise here!
Thread Tools
13.8V 80A Linear PS circuit design analysis for Ham Radio Use FJHookah Power Supplies 71 27th October 2019 02:52 PM
Is it tradition that we use linear PSUs for valve amps? Paul Uszak Power Supplies 9 2nd September 2016 10:58 PM
Audio Valve Eklipse volume pot value? Ki Choi Tubes / Valves 0 27th March 2015 05:22 PM
Londog Audio VDt1 Valve Output 24/192 DSD DAC mainscablesrus Mains Cables R Us 1 1st October 2013 06:52 PM
Audio Note DAC 2.1x valve DAC juancho Swap Meet 0 6th July 2005 09:16 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
