Construction Tips Construction techniques and tips
Building a Class Amplifier from Scratch
Old Today, 07:34 AM   #11
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
All good points PRR.
Old Today, 09:08 AM   #12
hpro is offline hpro  Switzerland
Default Step two in my Project to Create a Class A from Scratch
Guy thanks for input.. I just finished to make the board of the next step Version.. Still with a big *200Watt or more* RE.
But opposite to the schematic with the OP37 it's full trasistorized..
Since its from beginning on Class a, and it doesn't have a Current Source Transistor, its very hard to control, and I like to build amps with at least parts as possible..
So I use a PID to help control DC at the Output. It can be run without as well just pulling the IC and adjusting 0 Volt if needt.. thats it.. Tomorrow we will know, will apply Power this evening..
have some pics for you / tested only in Multisimm but version PCB old was tested in realtime and thats wha I had to make a new one.. and this I have to modify as well as Some Parts are to close to each other.,.
Using these Heat Sinks, I can save 8 transistors, it Generates less Heat * transistor only) and it's 75% less in weight. and this with almost the same Power . this one has a BIAS of 3.7 Ampere/
File Type: jpg 3..Class A sandwitch Trans bottom_s.jpg (356.6 KB, 12 views)
Old Today, 10:48 AM   #13
Old Today, 12:52 PM   #14
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
Originally Posted by hpro View Post
Hi everyone here..
Building a Class A Amplifier from scratch.
Nice build(s), thanks for posting
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Building a Class Amplifier from ScratchHide this!Advertise here!
Little help building Class D amplifier daKube Class D 2 15th February 2016 08:39 AM
Class D Amplifier -- building blocks Sch3mat1c Tubes / Valves 15 23rd July 2015 11:34 PM
Second attempt at Building my own amp from scratch Vostro Solid State 106 9th May 2014 01:21 PM
Building Class D amplifier with PIC16F877A RealForce Class D 2 22nd April 2010 10:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
