Working amazingly well, great low freq response, ideal for subs. Thanks Sunil.
WHICH COIL DID YOU USED ?
irfp260N should not hot, btw need to see switching freq, if more than 250khz ofc irfp250 and 260N will be heat slow rds on, change gate resistor 33 ohm, but the power output will be less. if you want full power for 250/260 change freq to 250khz then it will be ok. yes inductor is very important no 1 in class D amp, wrong inductor will cause lack power at output, i have build pair version this amp with irfp260N, very stable at +88 -88 vdc
WHICH CORE DID YOU USED?
i guess it is a good amp because wakhu post video on you tube of all his amps while they are working and also testing them with a huge load. e.g full bridge at 2ohms
hi sunil is your amplifier still working?Class d d4k5 Eagle File
My Design Eagle Brd File, PCB Pdf File , Orignal Gerber File,JLC PCB Photo, Amplifier 100% Work Ok
What exact frequency to operate irfp260 safelyWHICH CORE DID YOU USED?
hi sunil kindly post the brd and the sch eagle files for your amp. share as zip file .Class d d4k5 Eagle File
thanks in advance
my design , based on etjale 1200 watts .
the amp is clear but the hf noise at low volume is the issue
- Class D
- D4K5 DIY Class D Amplifier 2000W ( Gerber Files) - working PCB or fake ?
