Amplifier DIY kit recomendations
Amplifier DIY kit recomendations Please consider donating to help us continue to serve you.
Old 26th November 2019, 08:03 AM   #41
grahamgraham is offline grahamgraham  United Kingdom
grahamgraham's Avatar
I think he is referring to C5-C8. I don't know enough about choosing coupling capacitors but from my recent questions on my 6 channel TPA3116 thread the conclusion was suggested that the effect of upgrading is minimal.
On this board it appears that there are coupling caps after the op amps as well before the chip. I wouldn't risk mucking about with the board!
I have just ordered the 3e 4x100w TPA3251 board, I wonder if I will have the same reflections on sound. It will be compared to my two Parasound Zamp V3 amps in a bi-amped DSP set up.
Old 26th November 2019, 08:46 AM   #42
jimk04 is offline jimk04  United Kingdom
Maybe we start a 3e 3255/3251 improvements thread.
I have 3e 3255 2 channel and 3251 3 channel.
I was going to upgrade the big electrolytic caps...if only because it is easy to do!
I would be interested in any feasible improvements that can be made (not swapping smd op amps!)
Old 3rd December 2019, 09:39 AM   #43
Michelag is offline Michelag  Italy
excuse me the perhaps off-topic, doesn't anyone talks about this Sure AA-AB32313 ?
Is perhaps an old design?
Old 5th December 2019, 06:42 PM   #44
Kjaerlarsen is offline Kjaerlarsen  Denmark
Just got new capacitors for the amplifier. So this weekend I’m planning on replacing all capacitors around the op amps. Also the four big capacitors are going to be replaced.
Going to be interesting to hear the impact on sound.
Still going to try some tweaks before deciding on building a Hypex amplifier.
Old 5th December 2019, 09:37 PM   #45
What are you replacing them with?
Old 8th December 2019, 06:19 PM   #46
Bought Nichicon capacitors.
Going to replace the eight capacitors sitting before and after the op amps and also the four big ones.
Read about an American guy who replaced some of the capacitors in his SMPS, with apparently good results, so going to do that too.
File Type: jpeg F7214930-4A41-419D-B21A-1EF842E7F174.jpeg (248.8 KB, 227 views)
Old 19th December 2019, 12:39 AM   #47
Think is offline Think  Netherlands
Can you share that link?
Have you already done the mods and did you hear a difference?
Old 19th December 2019, 07:21 PM   #48
Bought them here:
Nichicon ES Capacitors - Audiophonics
The space for the four big capacitors are a bit limited, so they are a bit cramped.
The sound has definitely changed. Whether it is better or worse still remains to be determined. My hearing currently suffers from the change in weather, believe it or not. But I do suffer from tinnitus on both ears, and they are quite sensitive to changes in weather.
I will get back with a more thorough verdict when my hearing is better.
My wife though is not impressed with the changes......
Last edited by Kjaerlarsen; 19th December 2019 at 07:24 PM. Reason: Wife’s comments
Old 14th February 2020, 08:09 AM   #49
So, got to listen a bit more serious.
Low end has become even deeper and more tight, not something I really need, was more than good enough for my needs before the mod.
Midrange and high end has improved slightly, with a bit more transparency, but not easy to hear, so very minor.
If I where to choose, I would leave the amplifier as it was built from the supplier, and if you need something with better sound quality, it needs more drastic modifications beyond my current skills, or else, go look for something else.
Still a very very good amplifier for the money (around €200,- complete build cost).
That's my humble opinion.
Old 14th February 2020, 08:47 AM   #50
Thanks for the update. I still haven't got round to setting up my tpa3251 4 channel 3e board and mean well. Lots of other projects!
I'd be interested to see how you mounted the caps, please.
I too have wondered what are the critical parts to replace on a 3e board to up its ante.
Amplifier DIY kit recomendationsHide this!Advertise here!
some power amplifier recomendations cd-i Solid State 88 29th December 2013 06:44 PM
recomendations please falcoron Full Range 3 26th July 2011 02:19 AM
first diy dac recomendations? skvuppla Digital Line Level 2 26th May 2009 02:57 PM
Best amplifier (recomendations) for Fostex FE108ez? Guijs Tubes / Valves 4 2nd October 2005 06:38 AM
DIY Sub amp recomendations?? .::Jonesy::. Chip Amps 17 19th January 2005 07:36 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
