So I did try all those different potentiometers
Kuei Yang Wang said:
Konnichiwa,
Big Money?
My best Interconnect can be made per 1m pair for under £7/$14.
For that you get goldplated fine silver (99.995%) wire, "zero connector" RCA Plugs and Airdielectic with phantastically low capacitance to boot.
Takes less than 15 Minute per pair with a modicum of practice.
Big Money?
Sayonara
I am very interested in your interconnect, if you don't mind sharing?
Thanks...
PEC pot & impedance
Hello!
I just found a store (online, called Banzai Music), located in Berlin, Germany, who sells some PEC carbon pots of MIL-STE series. They offer values of 1kohm, 5kohm, 10kohm and so on, log. Now I'm asking myself the folloing question:
Wouldn't it be the best thing to go for a source with a really low output impedance (e.g. below 100 ohms), then add a 5 kohm pot, and then a power amp with a rather highish input impedance, say, something around 30 kohms?
I mean, wouldn't this be the best way to really avoid any active pre or buffer stage, without the usual drawbacks of a passive pre?
Please guys, let me know what you are thinking about that! The PEC stereo pots cost 47,30 Euro each, so I have to decide carefully which value might be the right one in my case.
Thanks!
martin
The problem with stereo PEC pots is poor channel matching. I had pots that had 6db tracking mismatch between channels and were completely useless for audio.
So while I was quite excited about them initially, I completely abondoned them later. If you buy 5 of them, chances are you'll find one with pretty good tolerance though 😉
Using single, preferrably linear pots, solves this problem and you can source them cheaply from DigiKey, however two separate pots for frequent volume adjustment are very unpractical.
The best way would be placing potentiometer directly at the amp.
Hi udailey, Hi Peter,
thanks for your answers! The problem is, that there are not many pots available that have such a low impedance value like 5kohm. Usually the whole thing starts at 10kohms and up.
I really don't like the idea of heaving two mono pots, so I guess I'll have to go for something else here. And I totally agree: I was shocked about the prices for the PEC pots!
But ok then, perhaps a TKD stereo 10kohm pot will also do the job, I'll try.
Regards - martin
I never tried TKD, although heard good comments about it.
Another option would be building your own discrete attenuator.
