Calibra DIGI 1600
Hi all,
received this amp in this condition, it is in protection.
can someone assist with a schematic please?
PSU has IRFP2907 & IRFP064N
Outputs are IRF640 & IRF9640
The rectifiers needed to be in the circuit when you measured the voltage on the inductors. Were they?
The voltage was likely from charged rail caps.
What's the resistance between the negative speaker terminal and the primary ground terminal?
What's the resistance between the RCA shields and the primary ground terminal?
