I haven't yet. I was tracing the Trace from the large resistor to see where the 22 volts is coming from. Be for the large resistor I geting 108 DC volt. After the resistor. I'm getting 22 volts. The same volt at the speaker terminal. After the large resistor it goes to the pin of the op-couplers
The collector of the PZTA56 goes to the negative low-voltage power supply. It's the same supply that feeds the op-amps.
are both Transistors this part number [PZTA56]?
I have fought these components to be fail.
R4039
R4113
R4011
R4013
R4108
C161
C181
- General Interest
- Car Audio
- Mtx ta92001 distorted output.
