Mtx ta92001 distorted output.
I haven't yet. I was tracing the Trace from the large resistor to see where the 22 volts is coming from. Be for the large resistor I geting 108 DC volt. After the resistor. I'm getting 22 volts. The same volt at the speaker terminal. After the large resistor it goes to the pin of the op-couplers
Corrosion under this capacitor. I'm gona replace both capacitor to be on the safe side none of mosfets are in and I was still getting 18 volts DC to the speaker terminal.
