Ok so with a close inductor in the amplifier (for testing) there was audio. But it started to draw over 3-4amps so I shut it off. Everything was working as intended, it maybe from the inductor not being high enough or of some other variable. I will build the inductor as specified I have 19gauge tho. I'll order the correct gauge.
I ordered everything. I repost after I receive everything and get it made up thanks for the information. Much appreciated.
Can someone help me with a conversion. If I need 80uH and m the tester is showing mH. How many mH is 80uH? Is it 0.08mH
Yes. A factor of 1000.
For conversions, you can type in the original and the units for the desired value and it will convert it. Example:
convert 80uH to mH
convert 80uH to mH
My apologize I sent you a link to the wrong part number. I looked for the right part and found this link to aliexpress. You may be able to source the part from a vendor here in the states. Or there is an equivalent that will work, but you'll have to do some research.
If anyone knows of a source or an equivalent part for the U30D40D, please chime in. I will look around when I have a chance.
Double checking, the part is not available from Aliexpress.
Aliexpress.com : Buy 5pcs U30D40D MOSPEC TO 247 from Reliable mospec suppliers on Shop2133149 Store
Does your inductor measure 80uH? If so, it should work. I would reuse the sleeve from the original inductor.
The original sleeve is cracked and torn I'm using this and some of the clear thick stuff I used on the zx2500.1
It's within +-5%
It's within +-5%
- General Interest
- Car Audio
- Kicker zx1000.1 (P083ZX10001-A) 2007 model
