My private blowtorch clone
Old 25th May 2020, 07:54 PM   #41
hesener is offline hesener  Germany
Originally Posted by DontHertzMe View Post
It's a great setup . I was just wondering what values you chose for the chokes and filters. Did you tune it to a specific frequency?
In fact I didnt, I used chokes I had for another project (a tube linestage, actually). Usually, I would calculate the input impedance (voltage / current at nominal operation) and use that impedance to calculate the filter so optimum damping without ringing could be achieved, but it doesn't hurt to make the caps a little larger, since this is not the output of a class-D amplifier. So, gut feeling it was , and it seems it worked.
Forgot to mention, of course when calculating a corner frequency has to be chosen , so that the damping at the "problem frequency" (usually the switching frequency of the DCDC converters) is high enough. There is a great book by Richard Ozenbaugh on EMI filter design that explains that procedure in detail.
Paradise documents are here: Link list
Old 25th May 2020, 08:09 PM   #42
BesPav is offline BesPav  Russian Federation
Originally Posted by hesener View Post
Did you measure the harmonics of this stage, with real , not super-matched transistors?
No, just because distortion itself can't help to estimate amp's performance.
I suppose, that all we need - is overall amplifier stability, while sounding really depends of components of actual build.
While we are really can reach ~100 dB feedback depth through all audioband we will feel all the ugliness of our measurement setups.
A very useful circuit indeed.
Also with independently biased LTPs could be designed something like this.
Old 25th May 2020, 08:17 PM   #43
I just wanted to check if the correction of mismatching that your circuit provides actually changes the distortion profile. I found that mismatch shows up as distortion, maybe 70dB down but still tells us something...
And of course you are right, distortion only is not enough, and with feedback a lot of issues can be covered (and some others brought forward).
I like that circuit, simple and elegant! do you control the corner frequency of the common mode control somehow? It seems it provides a lot of CM gain in the audio band
Old 25th May 2020, 08:31 PM   #44
Bad case matching obviously results in 1ma for 10 ma devices. This could be mostly eliminated with slightly different source degenerating resistances.
No, i haven't tuned that behaviour now, but there are nothing complicated.
Yes, curent-mirror-loaded LTP could provide up to 60-70 dB gain, so, again yes, loop could be unstable without proper tuning.
Oh, yes, mirrored second stage have much more swing, check attached.
Old 26th May 2020, 02:25 PM   #45
catd is online now catd  Europe
catd's Avatar
Hi!
... so I settled for aluminum-filled nylon....
That's interesting...
Is the material conductive? I'm looking for something non-conductive for the same purpose, but for transistors in metal case where the collector is connected to the case.
greetings
Old 26th May 2020, 03:21 PM   #46
Don't think so, but I haven't checked. I would have to re-open the case to do that, it may take some time, sorry.....
My private blowtorch cloneHide this!Advertise here!
Private messages Bonsai Forum Problems 26 24th May 2020 02:19 PM
When a Luxman clone is not a clone carlmart Solid State 68 3rd January 2020 09:16 AM
Generic Asian Clone driver board RE and Clone jacampb2 Car Audio 26 3rd July 2018 08:01 PM
FS: Drivers for JBL 250Ti clone (LE14, 108H clone, 104H-2 GordonW Swap Meet 10 20th May 2014 08:19 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
