What's wrong with this preamp circuit?
Old 25th September 2019, 11:31 AM   #1
Lysergium is offline Lysergium
Default What's wrong with this preamp circuit?
I've built a preamp, and it's not working, my amp/speakers do not want this thing in the circuit, bunch of popping, hissing, buzzing.
I have the input, output, DC wired the same as in my previous preamp, which works fine.
I used spare leads from resistors to make some connections in the circuit, could that be a problem? everything seems to be connected correctly.
I used BC547C instead of BC549, but they're basicaly interchangable, as far as i know.
Old 25th September 2019, 11:35 AM   #2
ubergeeknz is offline ubergeeknz  New Zealand
BC547C is fine.
Can you take a picture of your construction?
Do your DC voltages match the circuit diagram?
Old 25th September 2019, 11:55 AM   #3
bobo1on1 is online now bobo1on1  Netherlands
I don't see any power supply decoupling capacitors, and the circuit doesn't have very high power supply rejection
I suggest adding power supply decoupling capacitors first.
Old 25th September 2019, 11:58 AM   #4
I agree, this looks like a section and not intended to be used as a "complete" preamplifier.
Old 25th September 2019, 12:01 PM   #5
Mooly's Avatar
It also has very high gain for a line amp and will not accept typical line level signals without severe clipping and distortion. The gain is around 20db (X10 voltage gain)
Old 25th September 2019, 12:06 PM   #6
Oh, makes sense i guess. my previous preamp is connected to DC directly as well, but it works. Probably need to fix that anyway.
The cap is on the other side, because i installed the previous cap in the wrong direction, so was worried it's fried.
Old 25th September 2019, 12:13 PM   #7
Aside from @Mooly comment regarding gain.. you definitely need some local supply decoupling. A 100uF electro and a 100nF ceramic from DC+ to gnd on the board itself, or whatever you have to hand - the exact values don't matter much - might go some way to clearing up the supply noise (and possibly oscillation)
Old 25th September 2019, 12:15 PM   #8
I was redirected to this design, in a previous thread. was told this would work better.
So the problem is, it has no power coupling capacitors, and it can't accept line input directly form a guitar pickup (humbucker meassuring 7.5kohm)?
So i can fix the power input problem.
Can i fix the signal input problem? different input cap?
Or do you have another good, transistor based pre-amp circuit i could build? (12-18V power supplies preferable, since that's what i got, probably have others as well).
Old 25th September 2019, 12:16 PM   #9
Ah. The gain should be okay for a guitar pickup. I don't think you mentioned that.
Add the supply decoupling, and see how it behaves.
Old 25th September 2019, 12:23 PM   #10
Mooly's Avatar
The input impedance isn't all that high as it is set by R1 (150k)... I don't know what would be recommended for your pickup though.
The 0.22uF cap is fine for the input.
Maybe if you tell us what preamp does work then we might spot some obvious differences such as gain and input impedance etc.
What's wrong with this preamp circuit?Hide this!Advertise here!
The JC-2 preamp schematic on the website is wrong...Mr.John C? X.G. Solid State 114 16th August 2016 11:16 AM
What's wrong with this typicial preamp circuit? kaneneville Analog Line Level 15 7th October 2012 07:06 PM
Gainclone preamp problem, something wrong with psu? thepgo Power Supplies 3 27th July 2012 09:01 PM
What's wrong with this circuit? Redshift187 Power Supplies 21 8th July 2012 10:39 PM
Whats wrong with this circuit? Hamstein Tubes / Valves 13 14th May 2012 11:58 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
