Help needed: Linkwitz-Riley frequency response curves
Old 18th November 2019, 04:23 PM   #51
yannikab is offline yannikab  Greece
Hey remember me? Long time no see. I 've had the LR crossover delivered for a while now, but only got the chance to tinker with it now. Here's a frequency response graph from HOLMImpulse, for your viewing pleasure. The crossover point I requested was 60Hz.
Help needed: Linkwitz-Riley frequency response curves-png
Blue line is my audio interface recording itself with a loopback, as a baseline indication. Besides the frequency splitting, the crossover offers 13.6dB of gain which is pretty welcome. I think I 've come across this gain value in the past so I am assuming it's directly related to and a specific result of using the NE5532 opamps.
Actual crossover frequencies are 61Hz for the left channel and 62Hz for the right, so they got it right. I asked them to not go under 60Hz so they made sure the components satisfied that requirement. Just for fun, I 'll be measuring the capacitor values because I think that's where the small discrepancy between left and right channel comes from.
Just for fun, I hooked up a 10K resistor to each of the low pass and high pass outputs, connected the resistors, and measured the summed output:
As expected, the frequency response of the summed output is pretty much flat. Gain loss of 6-7dB is due to the resistors of course.
What can I say, it works. :-)
Old 19th November 2019, 04:23 PM   #52
Hello again,
I discovered this nice checkbox on HOLMImpulse's interface labeled "Distortion". I picked THD and these are the results for loopback, lowpass, highpass:
Help needed: Linkwitz-Riley frequency response curves-loopback-png
Help needed: Linkwitz-Riley frequency response curves-lowpass-png
Help needed: Linkwitz-Riley frequency response curves-highpass-png
Could someone explain what these additional lines indicate? They look quite irregular which makes me wonder. Especially the loopback curve.
Old 19th November 2019, 05:51 PM   #53
Gnobuddy is online now Gnobuddy  Canada
Originally Posted by yannikab View Post
...13.6dB of gain...I am assuming it's directly related to and a specific result of using the NE5532 opamps.
The NE5532 is a very nice op-amp that can be configured for any voltage gain from a rather useless zero (in inverting mode) up to x100,000 (i.e. +100 dB), its open-loop gain at DC and very low frequencies.
Perhaps your 13.6 dB is specific to the specific circuit used to achieve the Linkwitz-Riley response. The generic Sallen-Key active filter topology ( Sallen–Key topology - Wikipedia ) has unity gain in the pass band, but sometimes needs awkward values of R and C.
An alternative, very similar-looking topology, keeps the frequency-determining C's equal to each other, but tweaks the voltage gain of the op-amp above unity to achieve the desired frequency response; one gain for a Bessel response, another gain for a Butterworth response, and so on.
It's a lot easier to buy two 10nF 1% caps than to find one 10nF and one 14.7 nF cap, so the equal-cap-value implementation is much more practical in many cases.
Since your Linkwitz-Riley filter is two cascaded second-order Butterworth filters, one possibility is that the gain of each Butterworth stage is half of 13.6 dB, or 6.8 dB. I haven't researched that at the moment (in a rush), but that does seem a wee bit high from memory, particularly for a low-Q Butterworth response.
Another plausible explanation is that multiple Ebay sellers are all selling copies of the same circuit, probably published in Elektor or Wireless World a few decades ago, and the original circuit just happens to have had 13.6 dB of gain.
I wouldn't worry at all about 60 Hz vs 61 Hz corner frequencies - really a meaningless difference in such a low-Q filter type, where the "corner" is very imprecise and extends over quite a range of frequencies. A bit like looking for the edge of the rainbow.
-Gnobuddy
Help needed: Linkwitz-Riley frequency response curvesHide this!Advertise here!
6L6 / EL34 / EL84 / 6V6 frequency response curves? diaz028 Tubes / Valves 100 12th March 2015 08:57 PM
Advice needed: mixed order Linkwitz Riley crossover Zoodle Analog Line Level 16 17th January 2014 10:44 AM
Adjustable Linkwitz-Riley filter: Help needed with SPICE NebuK Analog Line Level 33 30th April 2012 12:27 PM
Piezo tweeter frequency response curves? Racket Scientist Multi-Way 0 1st November 2010 04:33 AM
Optimum frequency response curves in the bass range The golden mean Subwoofers 8 30th June 2008 05:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
