Pop/click free HW-based relay attenuator V3
Thread Tools
Old 20th November 2020, 04:38 PM   #111
gionag is offline gionag  Italy
Originally Posted by 454Casull View Post
Crazy question - does anybody have an expander PCB they are willing to sell?
I have a full assembled expansion and main board to sell
Old 21st November 2020, 08:21 PM   #112
Gluca is offline Gluca  Italy
Gluca's Avatar
Hi Neutrality
I put together the attenuator but I am having pops at -16 and -32. I am using just 6 relays, I got rid of the 1/2 LSB trick to simplify things (smallest step is non jumping so far) and using a 112.5Hz clock (8.8ms) to drive the flip-flops. Relays are panasonic TQ2 (3ms activating time according to specs). What should I look closer to fix it? I am not using you boards, I just made a few from scratches.
Thanks!
g
Old 22nd November 2020, 12:47 PM   #113
Neutrality is offline Neutrality  Denmark
Since you are not using my boards, but have built your own, I need to see the exact schematic of your design.
Old 22nd November 2020, 03:15 PM   #114
Gluca's Avatar
I inverted the relays!
When OFF they have no attenuation, when ON they attenuate. It should be the other way round ... basically when I am switching all relays OFF it pops as there is no attenuation at all. I also had to reverse the connections at the POT to increase vol clockwise. I will redo the board.
Old 22nd November 2020, 08:53 PM   #115
Glad you found the error.
Inverting the relays will indeed cause pops.
  Reply to this post
Pop/click free HW-based relay attenuator V3Hide this!Advertise here!
Thread Tools
Pop/click free HW-based relay attenuator Neutrality Analog Line Level 105 18th August 2018 05:21 AM
Pop/click free HW-based relay attenuator V2 Neutrality Analog Line Level 63 30th April 2018 09:24 AM
Marantz SR 18 No Sound or Relay Click epoxyman Solid State 1 2nd November 2016 02:17 PM
FS: Relay based stepped attenuator Earfanatic Swap Meet 7 22nd April 2013 03:08 PM
relay based attenuator squadra Solid State 21 1st December 2004 11:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
